Casio keyboard Lk-110 had 18volt input
The Casio keyboard LK-110 should have 9volt input power from a Power Adapter but my family did not no and put a 18volt power Adapter and Smoke came from the keyboard i check all the parts on the power board which there are not alot of parts and could not fine the fault I try Battery and a 9volt power Adapter and the light will not come On this is the first time I can not fine the fault the power board is straight forward check Diodes,transistor,and the PC900v,resistor this where i need help may be I miss something
Photos of both sides of the board that smoked with an indication of where you think the smoke came from please.
Casio keyboard
This is not my Keyboard and my family said it happen when they connect a 18v power Adapter and Because there are so many Screws on the bottom cover there are so sign of smoke when the cover was remove the only thing I will try is to replace some Capacitor show 6.3v some only show 16v and 25v i have test them with the ESR tester and had low reading I can not take a Photo as the picture will poor view
davenn
there could quite well be a long list of faulty parts
particularly the IC's and maybe some transistors
without more info it will be pretty much impossible to help further :(
Dave
Many more pictures needed, take from multiple angles so that we can better see the ICs, take a straight on shot of the back of the board...
Take these pictures outside in sunlight if possible to avoid flash hot spots and/or focusing issues due to lack of light... Or if you have a light box you can use that...
