Steven said:
Just check the current rating on those reed switches. They might not
last long switching on and off a high capacity bilge pump instead of an
alarm sensor circuit.
Steve
NO WAY have they got the required current rating, also I would be
concerned about water penetration of the magnet and reed units if you use
off the shelf alarm parts.
The idea does have merit however and if 'bare' reed switches and magnets
were encapsulated in epoxy, that sorts out the water intrusion problem.
To solve the low current rating problem you would need to use a relay
rated for the pump stall current mounted high and dry, far from the bilge,
controlled by the reed switch and add a diode accross the relay coil
(cathode positive, 1N4148 would be fine) to prevent arcing in the reed
switch. A suitable diode rated for the motor current connected across it,
cathode positive would also increase reliability by reducing arcing at the
relay contacts.
Some experimentation with the magnet strength and the seperation would be
required, but I see the posibility of using the magnet to provide
hysterisis in the switching action. (i.e. the switch turns off at a lower
level than that which turned it on)
The magnet is strongly attracted to a piece of mild steel when its really
close to it and the attraction gets much weaker rapildly as the distance
is increased. This could be used to hold the float up until it is nearly
out of the water before its weight can pull the magnet away fron the
switch assembly. Once its dropped, it cannot re-close untill more
bilgewater lifts it up again.
The difficulty would be putting enough mild steel in the reed switch
housing without interfering with the operation of the switch. If you use
2 pieces of steel, and dont put them near the middle of the glass reed
switch body, it should work ok.
Considerable experimentation and testing will be required to get a
reliable switch assembly suitable for use in a bilge.
Ian Malcolm. London, ENGLAND. (NEWSGROUP REPLY PREFERRED)
ianm[at]the[dash]malcolms[dot]freeserve[dot]co[dot]uk [at]=@, [dash]=- &
[dot]=.
*Warning* SPAM TRAP set in header, Use email address in sig. if you must.
'Stingo' Albacore #1554 - 15' Uffa Fox designed, All varnished hot moulded
wooden racing dinghy circa. 1961
