KrisBlueNZ
Sadly passed away in 2015
In that case you can use a "low dropout" (LDO) regulator. These can work with as little as 0.5V voltage difference between input and output, sometimes even less, so you could go down as low as 9.5V before the output voltage loses regulation.
How much current does the controller need?
Do you have a preferred supplier? I linked to Maplin before, but there's also Farnell / Element 14...
