Hello !
my old Marantz PM500 that I love so much doesn't work as well as before.
The EQ graph doesn''t work anymore, I'm obliged to push the "EQ Defeat" button to ear a decent sound.
I unmounted the amplifier and saw that a capacitor in the EQ's electronic board is defective.
I changed it and tried again but the problem stills here, so I unmounted the amp again and saw that the new capacitor is now defective too...
I took a lot of measures and found some anomalies but I'm not sure to interpreting them correctly.
Please may someone help me to fix my amplifier ?
I have the service manual, a lot of pictures and the results of everything I checked :
The dead capacitor is "CF11", it's inflated.
It is connected to pin JF07 which should, if we believe the diagram, be powered under -25V but I measure 25V.
I find -13V on all the pins of transistors QF03 to QF10.
According to the P400 diagram (page 34) :
-25V should arrive to JF09 from transmitter (E) of transistor Q802 via J804 connector, white wire
I have -24 VDC on the white wire PF00 card side, whether the EQ Defeat is activated or not
-25V should arrive to JF07 from the emitter (E) of transistor Q801 via connector J805, white wire red line, I have 24 VDC on the white / red wire, is this normal?
so after I took the Q801, Q802, Q805 to Q808 transistor voltages measurements and I find abnormal things there too but I do not know how to interpret them.
How to understand the following measures?
first number : written in the diagram
second number : measured
Q801 :
E : -25V : 24V
B : 25,7 : 24V
C : 39,5 : 39V
Q802 :
E : -25 : -24
B : -40 : -39
C : -25,7 : -25
Q805 :
E : 6V : 6,2V
C : 26V : 25V
B : ? : 5V
Q806 :
E : 6V : -5,56V
C : 26V : -25V
B : ? : -6,26V
Q807 :
E : 36V : 25,81V
C : 26V : 25,53V
B : 35V : 39,3V
Q808 :
E : -36V : -25V
C : 26V : -39V
B : 35V : -38V
pin number : tension indicated in the diagram : tension measured
QF01 :
1 : 0 : - 13 VDC :
2 : - : -
3 : - : - 7 VDC
4 : -22 : - 17 VDC
5 : - : - 17 VDC
6 : 0 : - 13 VDC
7 : 0 : - 13 VDC
8 : 22 : - 13 VDC
QF02 :
1 : 0 : - 13 VDC :
2 : - : -
3 : - : - 7 VDC
4 : -22 : - 17 VDC
5 : 0 : - 17 VDC
6 : 0 : - 13 VDC
7 : 0 : - 13 VDC
8 : 22 : - 14 VDC
Thank you in advance for any help !
Have a good Sunday !
Eyton
Q801 :
E : -25V : 24V
B : 25,7 : 24V
C : 39,5 : 39V
Q802 :
E : -25 : -24
B : -40 : -39
C : -25,7 : -25
Q805 :
E : 6V : 6,2V
C : 26V : 25V
B : ? : 5V
Q806 :
E : 6V : -5,56V
C : 26V : -25V
B : ? : -6,26V
Q807 :
E : 36V : 25,81V
C : 26V : 25,53V
B : 35V : 39,3V
Q808 :
E : -36V : -25V
C : 26V : -39V
B : 35V : -38V
QF01 :
1 : 0 : - 13 VDC :
2 : - : -
3 : - : - 7 VDC
4 : -22 : - 17 VDC
5 : - : - 17 VDC
6 : 0 : - 13 VDC
7 : 0 : - 13 VDC
8 : 22 : - 13 VDC
QF02 :
1 : 0 : - 13 VDC :
2 : - : -
3 : - : - 7 VDC
4 : -22 : - 17 VDC
5 : 0 : - 17 VDC
6 : 0 : - 13 VDC
7 : 0 : - 13 VDC
8 : 22 : - 14 VDC
Eyton
