I didn't find a 1pF ceramic capacitor yet but I have to search more
Meanwhile, I swapped all the components in the vicinity of QF03 by the ones near QF04 :
QF03 by QF04 swapped : no change, same problem
CF31 by CF32 swapped : same values as the manual, no change, same problem
CF11 : brand new, no change, same problem
CF41 by CF42 swapped : same values as the manual, no change, same problem
CF51 by CF52 swapped : same values as the manual, no change, same problem
RF31 by RF32 swapped : same values as the manual, no change, same problem
RF41 by RF42 swapped : same values as the manual, no change, same problem
RF51 by RF52 swapped : same values as the manual, no change, same problem
RF61 by RF62 swapped : same values as the manual, no change, same problem
A statement: the PF00 board seems hotter than other electronic boards. Not much more, but when PF00 seems lukewarm, the others (PH00 and the one for the volume and balance) seem cold to me.
Here a link to download a video that illustrates the problem when the RF21 fader is at the top position :
https://wetransfer.com/downloads/92...42abd582c1283c0074e9829520191123102317/91eddf
In the first part of the video, I putted the balance to the very right and only a high frequency noise is audible from the right speaker.
In the second part, I set the balance in the middle and when I put RF21 at the top, the volume is much more high, like the volume is suddenly pushed to the max of the amplifier.
A picture of the component's side of PF00 :
Below a picture of the other side of the board :
In the red circles, there are "01" ceramic capacitors between the first pin and the seventh pin of QF01 and QF02.
These components are not in the diagrams of the service manual.
Do you think it's normal ?
