Audio Marantz PM500
ESR/component testers on Ebay for £4.00. I bought one months ago to test it. It actually works pretty well.
I don’t use it often as I have an ESR meter. Might be worth buying one on this occasion.
Have you checked if there is DC on the amp speaker outputs?. It should be minimal in the millivolts if any at all.
Sorry, just chiming in.
Martin
on QF01 AND QF02 ?
..... the vicinity of QF01 ? QF02 ?
ALL the capacitors or juste electrolytics
Caps around Qf01 and Qf02. Electrolytics for sure, but it's possible others are bad too.
You've swapped components in this area from Qf01 side to Qf02 side and the problem didn't move to the opposite channel, so its possibile that a bad cap moved over but still caused an imbalance.
I wish I knew more about the role of opamp pin 5 plays on this.
I would love to hear from more knowledgeable members on the matter.
Could be a mis-print, can’t see the schematic atm.
Either way, it once worked. You seem to have narrowed it down to the EQ board. So, all works except a ‘fader’ distorts the audio?.
This happens on the LEFT channel only?.
I read earlier about a ‘hiss’ noise. Was it hiss or hum?.
And this noise is only audible when the EQ is turned on?.
I would check ‘fader’ resistances and cleanliness. Spray with switch cleaner/deoxit depending on what side of the pond..(some countries drive on the wrong side!).
Also, I would check solder joints.
With amp switched on and no input signals. Just speakers, put a little pressure on the board. Probe around, carefully of course. A magnifier may be useful here. Some non- electrolytics might have cracks.
But as this amp is late 1970s to early 1980s, it is due for a complete electrolytic replacement. Small ones included due to drying out.
Martin
I finally find the f***in' cause, these g***amn black wires :
There were between PF00 and PF01, I finally noticed that some were oxidized and some were half-cut.
So I changed them :
No more weird sounds, pink, white or brown noise !
Thank you all for your help !
yes you're right, I am waiting for a good caps kit for this amp, can't wait to receive it !
I found some more info on the QF01 and QF02 chips.
They are the Toshiba HA1457.
Can be useful for the future, thank you I will save the datasheet !
@Tha fios agaibh : a very special thank you very much for your support ;)
