Platforms
Content
Q601 measurements make no sense.
Looks like you switched C and E.
R611 and R633 measurements are switched?
Please confirm all measurements from #20 .
Please add the the DC voltages relative to GND on D601 and R609.
R601/602 adjust bias currents so compare left right channel for differences from input to output with schematic voltages.Q601 measurements make no sense.
Sorry about that, I kept getting interrupted and I got mixed up.
OK, Q601 Reads
44.9 V==>C
46.7 V==>B
47.4 V==>E
D603 Reads 46.8 V & 47.4 V
R611 Reads 1.45 V & 1.35 V
R633 Reads 45.5 V & 47.7 V
R609 Reads 1.45 V & 0.64 V
thanks for the corrections.Sunnysky,
IC701 is not blown.
The "second" i.e VR603 purpose is to set the idel current of the final Trs.
Your explanation of Q619 and Q621 is "off bias"
Q619 is not a peak integrator,it is a current sensor of the final Tr Q625 (Emitter current)
i.e the output current .
Q620 does the same for the other channel.
Q619 and Q620 are connected in a "wired or" arrangement.
If any of them conducts (i.e. due to high enough output current) then Q621 will conduct and trip the "over current sense" of IC701(pin 1) putting the AMP in protection mode (i.e. de-energizing the speakers relay and lighting the protection LED ) .
In this specific AMP we do not have the above condition(i.e no over current protection activated)!
O.K.
There is something strange in the readings of D603 cathode (46.8V) vs. B of Q601(46.7V),
as the base should be higher voltage than the diode cathode.I assume it is a measurement error.
Let's try this :
Measure the voltage on the Emitter of Q607 relative to GND (if possible probe constantly) .
What do we get ?
Q607 pin-out
Turn trim-pot VR601 gently with a small screwdriver ,can you lower that voltage?
If you can, to what voltage?
Please put the trim-pot VR601 in the position to produce 15.6V Emitter voltage on Q601(as it was in the first place).
Volume at minimum.
Measure the voltage on the junction of R645/R647 (0.22ohm ).
What do we get?
Disconnect the receiver form mains power.
Locate R627 (820ohm/2W).
Find it's Leg that is connected to the junction of R645/R647 (0.22ohm ).
Disconnect(un-solder and lift) that leg as marked on the pic below.
Connect well that resistor Leg to chassis GND with a wire.
Power -up the receiver.
Measure the voltage on the junction of R645/R647 (0.22ohm ) and Q607.
What do we get?
I can't find where R645 and R647 meet on the circuit board to get a voltage reading on the junction like you said. They look close together on the schematics but far apart on the circuit board. Is there another way to get a reading?
Somehow I overlooked those readings.
Then remove D605 clamp diode.
If reverse leakage is high uA, it will pull up the output.
changing feedback R641 to chassis 0v will only cause output to pull up all the way to 45V or so.
Volume at minimum.
What do we get?
What do we get?
