Platforms
Content
I guess it's possible but highly improbable that this option wasn't proposed somewhere lost in this epic odyssey.Another solution would be to interface these keys to a microcontroller and use it to create the analog voltage.
droop, drift, yeah its all part of the problem. There's no particular reason why it will always fall, so I said drift.
right from the start I was deluded by the MFOS 1V per octave keyboard when I proposed using the sample and hold,
something obviously wrong is that the noise toaster is only 18mV per octave!
<<SNIP>>I not sure how you intended for me to implement it but I hope that It could function as some sort of digital S&H so I can use the 34 existing analog pots.
The way I envisage it is that you would have only a single trimpot and use it for all the keys. The micro controller would only sample the voltage generated by it when you are "tuning" the keyboard with the digital value stored in eeprom.
I'd probably skip trimpots entirely and opt for rotary encoder or similar, however there's no reason you'd have to.
The issue with using a micro controller is that you will be limited to discrete voltage steps.
If i were to tune it to a typical musical scale the key voltages would only be a few mV apart for each note.How can that be? 9V divided by 34 = ~ 265mV.
Chris
(you can actually see visual evidence of the low voltage cut off in the NT demo video at this point)If this wouldnt work I now think the TL074 could maybe work!
my reasoning: when I was messing around with noise toaster before this project i distinctly remember that the frequency pot (top left of the schematic,this is what im duplicating for every key) must be turned up at least 1/6 before anything became audible,
a few minutes ago I tested what voltage a potentiometer voltage divider would put out when turned 1/6 the way up, it was around 1.75V.
the TL074 input offset voltage is 1.5V and its output tops off at around 8.75V , and it sample and holds perfectly, so that 1.5-8.75V range would be fine
Ok so I decided what I will do is build the sample and hold with a TL074 ,
I already explained how this will work here:
I know I explained this in that post where I quoted myself, did you see?The TL074 will produce an output offset voltage ~1.5V when used with a single ended 9V power source.
I probably missed or forgot it. It's been a long journey.I know I explained this in that post where I quoted myself, did you see?
''I know I explained this in that post where I quoted myself, did you see?'' I sound like im talking about a post that was made a week ago when I just meant post #68... I think Ill go to bed now hahaI probably missed or forgot it. It's been a long journey.I'm guessing that 1.5V offset is now acceptable to you. I know it wasn't at the beginning.
Chris
I have tested with the TL074 and polystyrene cap by manually sampling with 2 wires and it works good.why not try it with the components you already have (aside firm the 4066) and see how it works.
Of course, if you have to buy parts and pay freight, it may make more sense to buy everything now.
I'm most concerned with the schottky diodes as they have significant leakage and you may end up seeing them operate more like a resistor at very low currents.
depending where you're using these diodes, low leakage may be important. I'd have to go back to check...
I dont have the schottkys now but Im after testing the voltage drop of a standard 1N914 from 0-9V and I doesnt go over 0.4V.yeah, you may find that the thoroughly high leakage causes problems. But give it a go and see.
so my S&H is finally working and I can continue my project!Hey I'm an old fart! You'll get there someday (maybe?) and you'll find an hour ago, a day, 6days, maybe a month, all seem to run together with absolutely no discernible difference between them. Hell, I told my wife today that the Corn Beef Hash & Eggs she made for breakfast was great! She looked at me with aexpression and said.. "Thanks but that was last Thursday"!
Chris
