CDRIVE
You're correct. I didn't understand. So I re - read this thread 3 times to see if I missed a clue. As far as I could see I didn't miss anything that would hint that it's a DC level that's being sampled. One would need to go back to your Will A Basic Buffer Be Sufficient topic in which you posted this Keyboard Schematic and then move on to your Biasing This OpAmp topic to realize that your keyboard will be outputting DC levels (0-9V) which are set by individual Pots assigned to each key.
Before we move on to this FET topic we need to talk about this Keyboard Schematic. I didn't catch it then and I'm surprised that no one else did either but I doubt it's wired like that. It's far more likely that one pole of each keyboard switch is connected to the wiper of each Pot. The other pole of each switch are common to each other (jumped) which then output to R1 in the Noise Toaster.
Do you see why I believe this to be true?
Now, hopefully, we can move on to this S&H issue. First off.. No, you can't eliminate the Buffer (Your Voltage Follower) as you did Here. The Voltage Follower is needed to eliminate the RC time constant that will be inherent in that circuit. When you hit a key you will want the sample voltage to rise as fast as possible and not be lagged by the RC Time Constant created there.
So, to recap please tell us if this is what you want:
(1) When a key is pressed a voltage level of 0-9V will be Sampled and Held when the key is released.
(2) When another key is pressed the Sample voltage in (1) updates to the voltage setting (Pot Voltage Divider) of the key just pressed.
(3) I think that's about it.
Do I get it yet??
Chris
Do I get it yet??
Chris
