Ive finally got some pictures of the actual synth
First things first: There are 2 Noise Toasters !!!
The overview : the grey knobs are the keyboard frequency pots, 2 knobs for a black key, 1 for a white key,
the black keys are 'polyphonic' i.e they output 2 seperate CV for either NT, with a keypress you send 9V to 2 voltage dividers rather than 1, 1 switch 2 pots.
the white keys are normal, the same as in the diagram^, 1 CV goes to both NTs.
youll notice there are no switches for the NTs, instead the switches are replaced with 3.5mm jacks (Dont worry this was not my idea, a followed a detailed
guide and it works 100%) making the noise toaster a 'semi-modular' synth, like this
Korg MS20
with 2 noisetoaster PCBs this adds MASSIVE increase in functionality and possible variations of patches, but most importantly its allows full communication between the seperate PCBs.
The guts:
You'll notice the 2 Noise Toaster PCBs!
the little PCB to the far right is just an LFO and also a pulse generator that is used as a basic arpeggiator for gating the envelope generator (explained
here within the first minute) .
to the far left mounted vertically to the top NT PCB is the little board reserved for the keyboard's S&H circuit, there would be 2 circuits for the polyphony, one for each Noise toaster .
youll also notice the top NT is missing components... well its the secondary NT, it is missing the audio amplflier since you only need one
you can see the the wires from the keys connecting to their pots,
and the NT hardware is mounted on the panel but they are not wired to the PCBs yet
The backside: at the far right is power input
and beside it the power output, its just a splitter, they're wired tip to tip and ring to ring.
I have 1.5A supply and the NTs consumes a grand total of 30mA ,
So anyway Im building a simple sequencer right now for use with this synth and I plan is to be able to power it with the same supply plus any other analog music machines that i may be building in the future.
... other than that not much else going on back here
so yeah Ive managed to make this 10 times more complicated for you but I hope finally having a visualization of this mystery 'synth' will make up for that.
