Help Wiring Voltage Regualtor
I found this circuit diagram for a LM1084 regulator and I've wired it up on my bread board but I'm a little confused as to where the "final regulated voltage" is suppose to go. I've placed positive and negative multimeter probes accordingly and I get zero volts from the output voltages. Can someone help me out with this?
Here's the original schematic: http://www.electroniq.net/power-supply/lm1084-voltage-regulator-circuit.html
Breadboard Wiring. For some parts I used different values because those were what I had on hand.
Specs: Top R=470ohm, Bot R=1K, 1uF electrolytic cap, 0.1uF ceramic cap, 9 volt battery source
