While beginning the task of replacing a broken fuse holder in a sound effects processor unit, I discovered loose wire with a resistor attached to the end of it. The other end was attached to the chassis ground of the unit. I'm thinking the resistor lead broke off of the 115/230 voltage selector switch since that's about the only thing the short wire could reach. There are two terminals on the switch that are joined/linked together on the 115 end of the switch.
Does it make sense that this resistor could have broken off of those joined terminals? I'm not an electrical type guy, but can solder the replacement fuse holder in and if I have to, reconnect the resistor.
Any advice will be of big help.
Jack
Jack
