Can someone explain, in simple terms, why high feedback is considered
inferior to low feedback in audio circuits? To me, linear is linear
and
a high feedback op-amp circuit is linear. Apparently, that isn't
entirely
true.
Thanks,
Gary
Abby,
The phenomenon you refer to (increased distortion when feedback is
applied) is called “transient intermodulation distortion” (TIM). TIM
was a hot topic in the early 1970s. You don’t hear much about it
nowadays because it s causes have been identified and, thanks to
faster semiconductors, have been eliminated. Here’s what happens: If
the slew rate capability (maximum rate of change of voltage with
respect to time) of any stage of an amplifier is lower than the actual
slew rate of a signal, then the output can not keep up with the
input. The result is a very large error exists between the input and
the feedback. This error causes the input stage to saturate. When
the output finally “catches up” to the input, it takes awhile for the
input stage to come out of saturation. During this period a large
intermodulation distortion component appears at the output.
In the 1970s, power transistors were quite slow, preventing the output
from keeping up with the input. Today, TIM is easily prevented simply
by designing the open loop amplifier so that all stages have adequate
slew rate capability. As long as this is the case, negative feedback
will always result in lower distortion, and no distortion artifacts
will occur that were not present in the open loop amplifier.
Regards,
Jon
