Bjarne Bäckström
Sorry, I didn't see the original post.
Google for "transient intermodulation distortion" and "Matti Otala".
Some classes of higher-order filters ring, some don't at all. More
math.
Jan Panteltje said:There is actually a simple solution to that, one I thought of
in the seventies, and was actually used in commercial designs.
Put a simple transistor stage before the power amp (in the power amp),
and make sure that transistor stage limits just before the power amp does.
The transistor stage needs no feedback, and the power amp always works
in the linear range.
When clipping happens, in the transistor stage, the output looks nice.
Sylvia Else said:If one were going to go after purveyors of that kind of gear, then for
consistency, one would also have to go after a large part of the entire
cosmetic and beauty industry. In common with the impugned audio
equipment vendors, they too are at best selling people the means to
delude themselves.
Which is not to say that would be a bad thing, but it illustrates the
true scale of the problem.
Adrian said:Several of my own P.A. designs (all transistor) have soft clipping in
the driver stages. On the occasions where I have had to run them
overloaded[1], they sounded much louder than their numerical wattage
would have suggested and there were no complaints about distortion.
John said:Gaussian and Bessel (linear-phase) filters don't ring, no mater what
the order.
You can make a sharp-cutoff (delay equalized) analog filter that
doesn't ring, but it's a pain.
True.
Since ears aren't phase sensitive at high frequencies (especially
above 20 KHz!) a little ringing doesn't matter anyhow.
Vladimir Vassilevsky said:Adrian said:Several of my own P.A. designs (all transistor) have soft clipping in
A typical audiofool ignorance.
The amount of nonlinear distortion = deviation of the transfer curve
from the straight line. Soft clipping = more distortion if compared to
hard clipping to the same ceiling.
If the amp has to enter the area where it clips the signal, one has to
limit the windup of the integrators in the feedback path. So the
recovery from the saturation will be quick.
delude themselves.
Jim said:I haven't rolled my own power amplifiers for 30+ years now.
In the past, though, it was my standard procedure to have way more
than adequate _real_ audio power... like 100W per channel in my living
room ;-)
But, I also utilized soft clipping in the driver stages to ensure I
didn't rail the output stages.
I always used RF-grade BJT's in my designs. If I were to build
something again I'd still use BJT's... since I have, in my secret
pocket, a way to A-B bias reliably ;-)
math.
Ringing can be a linear phenom, in which case it's just peaking in the
frequency domain. And if the ringing is above 20 KHz, there's nothing
to peak and nobody can hear it anyhow.
John
I'll have to add "grittiness" to my list of audio metrology terms...
5N, 6N, 7N (as in 99.99999 pure copper)
acceleration
agressive
air
articulation
bass transient response
blackness
bloom
bright
burnin (cables)
clarity
color
confused
congested
continuousness
crisp
delineation of inner detail
dynamics
effortlessness
etched
extension
fast bass
free-flowing ease
grainy
granularity
hangover
hard
harmonic completeness
hashy
holographic
honesty
impact
jump
layering
liquid
liquidity
liveliness
lush
macrodynamics
microdynamics
musicality
openness
pace
quantum purifier
reference
refinement
relaxed
roundness
reveal
single-crystal copper
slam
slow bass
smear
soundstaging
space
sparkle effect
spatial resolution
speed
stunning (everything is stunning)
thin
tight
tight (bass)
timbre
tipped-up
transparency
truth
unfussiness
wire direction
krw said:Sorry, I didn't see the original post.
[...]Hi,
Can someone explain, in simple terms, why high feedback is considered
inferior to low feedback in audio circuits? To me, linear is linear
and
a high feedback op-amp circuit is linear. Apparently, that isn't
entirely
true.
Thanks,
Gary
You should be able to answer a question that's been bugging me. Which
do audiophools spend more money for, speaker cables or HDMI cables?
On Fri, 23 Jan 2009 17:08:00 -0800, John Larkin
[snip]stunning (everything is stunning)
thin
tight
tight (bass)
timbre
tipped-up
transparency
truth
unfussiness
wire direction
"Toasting". A process of processing a cable which improves the
fidelity of such cable. Cables that are toasted are directional.
Unfortuantely, I can't find the original reference to toasting cables
which was most amusing to read. The testimonials proved the worth of
toasting.
http://www.noteworthyaudio.co.uk/Services.html#4
http://www.ultraaudio.com/opinion/20030801.htm
Terms in the second link...
vividness
tonal accuracy
It's all coming back to me now...
Anyone, besides me, remember when cactus needles were all the rage for
stylus use ?![]()
In your opinion, would a filter that has no overshoot in the time domain be
capable of ringing?
krw said:No, the users of cosmetics delude others, which is exactly what the
manufacturers advertise.
the order. Sharp-cutoff (Butterworth, Chebychev, elliptical) filters
do.
doesn't ring, but it's a pain. Digitally, it's easier.
John
DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
On Fri, 23 Jan 2009 18:27:12 -0700, Jim Thompson
I'll add it. Is that measured with a thermocouple?
John
John said:On Sat, 24 Jan 2009 16:58:14 -0800 (PST), "[email protected]"
I don't get that. A simple CRCR network can have an impulse response
that swings negative, but it doesn't ring.
