abby said:
Can someone explain, in simple terms, why high feedback is considered
inferior to low feedback in audio circuits? To me, linear is linear
and
a high feedback op-amp circuit is linear. Apparently, that isn't
entirely
true.
In an amplifier with a distorted transfer characteristics [volts in /
volts out], adding feedback can linearise the characteristic over the
working range. This gives lower distortion figures over the working
range but it means that the amplifier distorts sharply and very badly
when it eventually does overload.
A slightly distorted waveform contains unwanted lower harmonics and
intermodulation products and doesn't sound particularly good, but a
sharply distorted wavform contain much higher harmionics which sound
absolutely vile!
If you can be sure of keeping the amplifier within its working limits at
all times, feedback is generally a good thing, but if you overload it
(even slightly) it can make things sound a lot worse. Smaller amounts
of feedback would be a good choice for guitar amplifiers or a small
P.A. amplifiers which may spend significant parts of their working
lives runing at (or somewhat above) maximum output.
An amplifier which has limited slew rate will not have that slew rate
improved by feedback, but the type of distortion it produces can be
changed and may sound a lot worse. Again, as long as you know that your
signal isn't ever going to exceed the slew rate of the amplifier, heavy
feedback may give useful improvements in other parameters.
