The MMUN2132 was replaced today, as it was clearly shorted.
Putting the PCB back into the machine I am now confronted with another fault code, F06, motor tacho failure... which seems reasonable as the motor is not being powered. I cannot hear the relays engage on the board when trying to power the motor, hence more must be out of whack with the PCB.
I can confirm that the machine now does control most of the components properly, water valves are opening, drain pump is running, door lock engages, etc.
One step closer, I guess?
Next up is doing more testing of the PCB, not sure what to look at next, something is keeping those relays from tripping, need to figure out what. Maybe the other MMUN2132 that switch the motor relays on are shot two? That seems unlikely... I have also not checked the motor triac yet, but I doubt that is the problem here, as it is not even engaging the relays, thus triac isn't even being powered just yet.
Will post back when i know more.
