I found this forum via Google and this excellent thread. I have a washing machine Whirlpool AWE 6516 that started throwing F23 error. If set on normal washing program It takes some water, spins a few times and in about 10s the error is displayed. The same happens if I run the test program.
What I've tried so far:
1. I checked the hose of the pressostat and the pressostat itself - it clicks when the machine takes water and the contacts appear to be working.
2. For extra safety, I replaced the pressostat with a new one.
3. I checked the cables and connections between the pressostat and the main board (L1373).
4. I checked all three relays on the board by powering them with 9V DC and measuring the contacts.
5. As advised on another forum, I checked the 470kΩ resistors immediately after the pressostat.
6. Heater is OK, no leakage.
7. I replaced the heater with a lamp; same behavior (the lamp doesn't lit up but that's probably because the error is thrown before the heater is powered).
8. I changed the polarity of the power supply.
9. The drain pump is working.
When I disassembled the machine I noticed a dead centipede on the back of the main board. Is it possible to cause damage to the board? There are no obviously burnt elements. Any ideas how to proceed further? I attach a photo of the centipede.
