Sir brians2005 . . . . . .
This write up is being related to only one of the units motors.
Can you initially locate R 019, with it being almost dead center of the schematic, and set up two connected test clips so that it will then be able to short them out, at a just later test..
You then power up the machine and listen to the attained motor speed and then basically short out that resistor by touching the leads for just enough time to see if you can then aurally detect a motor slow up.
That would be robbing the variable pulse width drive to the motor control SCR, thus slowing the motor, and everything downstream should probably be OK.
Then there wouold be a need to more fully check out the top left corners tach feedback circuitry.
This is all considering that this is the specific motor that you are having problems with.
Otherwise, back to the drawing board, to fill in the info on the other motors involved circuitry , as I had done this schematic plotting, only for this sole motor.
Relevant Prior Write Up:
https://www.electronicspoint.com/threads/whirlpool-l1373-repair-attempt.280704/page-2
Relevant Prior Schematic:
73’s de Edd
