Sir bijanelectric . . . . .
I did solder the 30 nF capacitor back on the board and installed it to see if the board lights up but it did not. So either the capacitor HAS TO BE the correct size or there are other issues as well.
You need to get off your " fixation " on that now removed C29 ( et twin C30) " snubber cap " (s) as being relevant to your units basic problem.
When a a diode is conducting it will create charge carriers to carry the current - this is known as "charge storage".
When the voltage reverses as part of the normal AC cycle (50/60Hz typically) the current will keep flowing through the diode in the reverse direction until the stored carriers are depleted.
When the carriers have been flushed from the diode, then the current will abruptly drop to zero and the voltage across the diode will suddenly rise. This can generate high frequencies up to tens or hundreds of Megahertz. This can interfere either with the equipment itself or radiate (or conduct via the power cable) to other equipment. The capacitor suppresses the effect of this interference. Often a capacitor will be put in parallel with each diode rather than a single capacitor across the AC input..
Any interference will usually have modulation at twice the AC input frequency and appear as a buzz in radios or audio amplifiers or could cause havoc to digital systems.
Therefore, the use of those capacitors . . . . aka . . . "snubber capacitors" . . . . across rectifier diodes is to reduce EMI / RFI.
AND . . . .they CAN also round down the peak/ dampen an incoming transient voltage spike from the power lines.
Usually there are 4, with one across each diode, in your situation they skimped down to 2 units . I see usual choices made of 0.001 ufd or 0.01ufd values, and up to 1000v ratings on direct AC line operated uses FOR THEIR VALUES.
In my seeing their choice / use of a monolithic block ceramic capacitor and permissible "creep" voltage isolation parameters, therewith, I can thereby see that this is not going to be a full AC line voltage supply, but instead, being a 12VDC'ish level supply with even a potential sub supply being derived from it also .
Thereby, only the need of a 50-100 V cap voltage rating for the two C29-30 caps..
IF I had any photo that was able to reveal C34 E-caps rating, I would then, at least, minimally know the max voltage to expect from the supply.
I have created a conversation /personal message to you but with no comeback response from you to date. I need your eyes and ohmmeter testing since those Dumb Ass Sh*ts chose to use a GREEN foil resist atop a GREEN board
Thaaaaaassit . . . .
73's de Edd . . .
It's my cat's world . . . . . I'm just around to timely open her food cans.
