Bob Myers
Radium said:AC -- by definition -- requires that the current reverse its flow.
A changing voltage isn't necessarily AC. Its only AC if the current
changes direction. Otherwise its still DC.
w_tom, unfortuately, brought in a concept that you are clearly
not ready to deal with. Mathematically, ANY function which
changes with time - which clearly covers any electrical waveform
that is not absolutely constant forever (which, if you want to be
extremely pedantic about it, is what "DC" really "should" mean)
may be expressed as the sum of a series of sinusoids. In some
cases (a "perfect" square wave or impulse are both good examples)
you need an infinite number of sinusoids to precisely equal the
desired function, but the math DOES work out. And in a practical,
real-world sense, if you filter an impulse you can in fact isolate
"real AC," even though you can also say that the impulse appears
to be going in "only one direction." This is why, for instance, you
can hear a seemingly "DC" discharge (lightning, or even a simple
static spark that results from shuffling your feet across the carpet)
on a radio.
A DC impulse is a impulse that -- for a relatively short duration --
increases its strength of flow toward one direction and then stops,
without reversing its flow.
It would certainly seem to be just that, but it works out to be
somewhat more complicated than it would first appear. You'll
need a pretty good grounding in calculus before you'll be able to
see why this must be so.
Bob M.
