Sjouke Burry
I have already eaten it.Bob said:Damn, John, now you're REALLY going to send Radium, et
al, down a rathole.....
I'll get the popcorn...
Bob M.
Bob M.
Bob Myers said:Up to the breakdown point, I think you'll find that
the I vs. V curve for a reasonable amount of separation in a
vacuum is pretty damned flat...
Sjouke said:I have already eaten it.
Doesn't a vacuum has very *low* resistance?
Or are you referring to the
stuff around the vacuum? What is the insulation covering the vacuum
made of?
jasen said:heat the negatively charged end and it has a relatively low resistance.
(see thermionic tube)
when cold untill you get the voltage high enouh to extend the
electron orbitals across the gap or to strip ions off one electrode
it's an insulator.
typically some sort of glass, a cheap, relatively good, insulator, only
problem is how brittle it is.
Radium said:Interesting, how some materials lose resistance when cooled while
others lose resistance when heated.
What is the breakdown voltage of the glass?
w_tom said:Furthermore, you are asking about resistance - DC electricity.
Lightning is an AC source. Therefore ask about both resistance AND
reactance.
Some sources describe lightning as being neither AC nor DC but *much*
closer to DC than AC. Others state that lightning is AC. Who should I
beleive?
Homer said:It's DC but it's an impulse.
True. AFAIK, a smooth sine-wave current [DC or AC] can only be produced
artificially. Of course I could be wrong.
Preferably infinite. LOL
Ummm...which is the "negatively charged end" of a vacuum?
Good idea. I remember reading about a small (relatively speaking)
Tesla coil that was supposed to be able to produce a few million
volts. It was in a large horizontal oil bath.
One of the benefits of oil - gets in all the tight spaces and prevents
corona which leads to insulation failure and lowers breakdown voltage.
Radium needs to build a few Tesla coils for an appreciation of
insulators.
w_tom said:A basic engineering and a basic mathematical concept: an impulse is a
sum of AC waveforms at many frequencies. The shorter that impulse,
then the more AC frequencies are in that impulse.
The term DC impulse is a contradiction or oxymoron. Either it is an
impulse - a sum of many frequencies - or it is DC.
For example, to determine the frequency response of a circuit, we
apply an ideal impulse. That ideal impulse applies every frequency to
the circuit. Circuit output is then captured to learn how well each
frequency transverses the circuit.
Many AC frequencies in lightning that make lightning challenging;
requires both resistance and reactance considerations. Those many AC
frequencies also appear as noise in radio reception. Lightning is AC.
Impulses are summations of energy in many frequencies - AC. That
concept is demonstrated in both advanced mathematics and in basic
engineering education. To appreciate the concept, get a first year
electrical engineering book and read about impulses. Concept is that
fundamental. A DC impulse is speculation often found where the math
and engineering were not first learned.
AC -- by definition -- requires that the current reverse its flow.
A changing voltage isn't necessarily AC. Its only AC if the current
changes direction. Otherwise its still DC.
A DC impulse is a impulse that -- for a relatively short duration --
increases its strength of flow toward one direction and then stops,
without reversing its flow.
