Hi:
Is there any material that has enough electrical-resistance to block
off high-voltage such as that of lightning? Lightning is around a
million volts.
Around a million? Not several millions? Cloud to ground strikes can
be several miles long and range into the hundreds of millions and
billions of volts, and tens to hundreds of thousands of amps.
Another question. Which material has the strongest electrical
resistance of all?
Lots of electrical texts have charts for dielectric strength. I
doubt that one insulator will be right for all applications.
Dielectric strength is specified in volts per mil, so even poor
insulators, if thick enough, can stand off high voltages.
What was your idea? Surround something with an insulator to protect
it from lightning? Surround what?
Lightening is a fast rise time pulse(s). The insulator, even if it
withstands the strike, will likely couple enough energy to the
"protected" device to cause damage
All the practical systems of lightening protection I'm aware of, deal
with directing the strike away from something, or bleeding off the
space charge before a discharge can occur in that area.
