netvoy
I have read the faq and find myself with the predicament that I too
want to figure out if a ballast is good. It is obviously not a good
idea to test it live as per the thread where I captured the information
below. If I interpret the information I've read so far at startup the
277(two different 120v circuits power several four bulb setup in this
kitchen) volts rated ballast I have is capable of putting out up to
600v and since the wires are dangling during the test and without a
load it is likely that the rated voltage will not dissapear of them
wires; the load in this case two flourescent bulbs (48 inch in my
case). Yet this voltage endangers me and if I were to measure; it is
likely useless unless loaded.
I digress. My intention is to understand what the post below refers
to as polarity. I have a pair of red, a pair of blue, a pair of yellow
and the black and white wires. Is polarity an issue at all three
pairs? Is it an issue at the red and blue pairs? The wiring schematic
at the ballast is not very clear on the particular label of a + or -
connection.
Is the yellow pair considered a filament just as the red and blue
pairs?
If a ballast goes bad will the second automatically be damaged or
likely damaged?
Thank you very much for any additional info....
[email protected] said the following to All on the subject of
How-to Test Fluorescent Ballast (24 Sep 97 17:12:35)
bc> I have checked the FAQ and have searched the WEB, but I have not
found
bc> any information on how to test if a fluorescent light ballast is
any
bc> good. I will be helping to re-lamp my daughter's gymnastics club
in the
bc> near future and I would like to test the ballasts that seem
bc> questionable. These are standard four-foot, two lamp fixtures that
are
bc> row mounted. I have installed new fluorescents many times, but I
am not
bc> familiar with the internal operation of a ballast. Any help that
you
bc> can provide regarding ballast operation and test would be
appreciative.
bc> I have a multi-meter, but is there any (low cost) specialised test
unit
bc> or methods that might be necessary.
A ballast is a simple transformer with a very high impedance secondary
winding which makes its current self-limiting. It also has windings for
each lamp filaments. At startup the filaments get most of the power and
heat up to facilitate ionization.
Meanwhile the secondary builds up a very high EMF which finally fully
ionizes the plasma between both filaments. At this point the effective
resistance of the conducting plasma is quite low and the current flow
is
limited by the secondary's impedance. This also partially saturates the
core and as consequence reduces power to the filaments.
The usual failure in ballasts is that the secondary's insulation
deteriorates and it starts leaking to ground. Often because the proper
wiring polarity was not observed. The secondary can thus no longer
generate the high EMF required to start the plasma conducting.
The KISS test method is to use a known good lamp. If it lights, the
ballast is good too. The ballast can also be tested with the power off
by
checking for continuity in the filament windings and a very high
resistance to ground for each filament. Don't try this with power on!
connection.
pairs?
likely damaged?
found
any
in the
are
am not
you
appreciative.
unit
is
by
