What's that black dust in monitors?
Jackie
What is that fine black 'dust' one sees inside monitors when the case is
removed?
Just curious
Jackie
G
GT
You know how you type away at something, but your PC hasn't responded, and
your keystrokes have been lost?
Well they haven't really.
That 'dust' is thousands of dead keystrokes.
Arpit
Yep. and its very very toxic. since youve opened the back, youll have
dislodged some, which means its now ILLEGAL to dispose of it in
standard tips. You cant vacuum it, or your vacuum cleaner will spray
it straight through the filter into the air. only thing i dcan think
of is to sprinkle it on your keyboard, from whence it came.
Phil Allison
removed?
** IME it can be one or more of the following:
1. Residue of cigarette smoke collected by the EHT wiring.
2. Photocopier toner dust similarly collected - if a copier is nearby.
3. House dust collected and carbonised by the huge voltage gradients
around the EHT wiring.
Horrible stuff in all cases.
.............. Phil
amstereo - matt2
also seen on the casing around the ends of fluro tubes, and anywere that
heat is generated consistantly (cd players, printers, VCR's (not nesesseraly
around the power supply) .
i think its carbon from heating crap in the air,but i'm not sure.
Rod Speed
You get it even with no smokers around at all.
Ditto.
the huge voltage gradients around the EHT wiring.
Its too fine for that.
Its actually the result of arcing, and much worse when the FBT is dying.
Wont do you any harm.
Rod Speed
and anywere that heat is generated consistantly (cd players,
printers, VCR's (not nesesseraly around the power supply) .
You dont see the same very fine black soot like stuff
in a VCR as you see inside a monitor outer shell tho.
Nope, you dont see it with say a fan heater.
but i'm not sure.
Its basically the result of the arcing thats inevitable in a monitor
and much worse when the FBT is dying or has died.
Adrian Jansen
Its that final resting place for all those bits and bytes you consign to the
recycle bin.
Regards,
Adrian Jansen
J & K MicroSystems
Microcomputer solutions for industrial control
K
Ken Taylor
recycle bin.
I thought it was all the left-over half-cycles from half-wave rectifiers.
Ken
Rod Speed
Cooked skin mostly (carbonised dust).
Dont believe it. Its too fine for that and the distribution
inside the outer case doesnt fit that either.
Phil Allison
** All the facts fit.
Electrostatically charged soot consists of very fine particles,
follows air currents and sticks to plastic and metal.
............... Phil
