L
L. Fiar
little billy said:This does not make any sense at all. Everyone here
says that the the requency is 50 Hz. I know the
electricity works at 50 Hz, this does not mean that
the electromagnetic waves of high power cable lines
are 50 Hz. For example, whenever I drive near high
voltage lines my am radio goes all haywire.
As others have made clear, this will be due to a problem with the power
lines.
One thing to remember is how easily AM (MW and LW) radio is interfered with.
So damn easy, in fact, that the RIS (Radio Investigation Service) have
outright refused to deal with any such interference complaints for several
years now.
This means that at least some of
the radiation is at 100 - 1600 KILO Hertz.
Once you get arcing, you get broadband noise which can interfere with any
receivers, radio or TV. AM receivers are more prone to such problems than FM
ones.
Such emissions are not to be relied upon for a reliable detection of power
lines. The nonexistence of such emissions does not mean that power lines are
not there.
I can't believe someone suggested to build
a 5000 km antenna to test these waves, I assume he was
making some sort of joke of my question. Obviously, any
detector should be smart enough to use a detection
method which doesn't involve builing a 5000 km antenna.
Have you thought about using a loading coil to shorten it
If you are referring to "Rick" <[email protected]>, then he did not suggest you
actually do that, just that the wavelength was that size.
