What component can alter electric flow if there is a voltage applied.
Hi
I need a component that works in a similar way to a mosfet. However rather than act just like a switch I would like the circuit to act like an alternate switch.
In my circuit shown I have tried to explain what I mean. Lets say with switch A open, then the green LED lights. When switch A is closed (contact made) then the red LED lights.
What I need to know is what type of component do I need at SW B position to achieve this.
If you have a specific item code that would be fab. The voltages are 5-7V and 500mAh.
Any help would be appreciated on this. I need it to be a small component similar to a IRLD014PBF mosfet.
Thanks in advance
JPU
Two MOSFETs will work. They can be found already wired together in a CMOS inverter.
However, you better put some resistors in series with the LEDS. and if you use a single inverter, you would have to wire one LED to ground and the other to V+.
Bob
