amdx
John Fields said:---
You obviously either misread me or you're just trying to be combative.
The point is that, if there were no bounce, the only stress the
contacts would experience would be the momentarily increased I²R
losses at startup; no big deal.
However, since the current is so much higher during startup, bounce
will result in a plasma capable of doing much more damage to the
contacts than the one created when breaking a resistive load.
Ok, my new relay has two sets of contacts, If I parallel the two sets,
am I doubling the chance that a set of contacts will weld themselves
together?
Is it less than a doubling?
Is it paralleling the contacts a good idea to increase MTBF?
Someone suggested a snubber across the contacts, seems to me it was big
enough to help, it would allow "quite" a current to flow in the motor.
Mikek
"quite" a word to use when you don't have a clue.
