Transistor, 600V@2A?
Bob J.
Hi, all,
I am looking for transistor, 600V@2A. Could you tell me part name and
company?
Thanks,
mike
Bob said:
Hi, all,
company?
Thanks,
It ain't anywhere near that simple. You need to know a LOT more about
the application (load line if you will and speed required) even if you
really don't need the 1200W you specified.
mike
Wanted, Serial cable for Dell Axim X5 PDA.
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
the
Thats right Mike, a switching transistor 600V @ 2A are as common as flys
Bob said:
Hi, all,
company?
Thanks,
mike
mike
I'm interested. How come you didn't name off a few dozen?
The 1200 Watt package is gonna be interesting.
mike
mike
mike
Jamie said:
did you ever think that maybe the application for it's use
maybe a simple logic function and not an analog function ?
Horizontal output transistors would most likely serve for
this function.
just think, use the transistor in saturation state or
near to it, the ESR in the transistor would be very low in deed.
just off the top of my head i could guess a 0.6.. 1.0 Vdc could be the
average voltage across the E and C points. do your math on that one.
you will find that its not so ridiculous after all.
Nobody said nuthn' 'bout ridiculous. What I said, was that choosing
a transistor is not that simple and some specificity would be in order.
We have only one data point 600V @ 2A. 600V AT 2A is 1200W.
What I THINK is irrelevant. The only thing that matters is the
REQUIREMENTS for the device in the user's application. Those
requirements were unspecified.
Now, we could make all kinds of assumptions. Maybe it's 600V OR 2A.
Or maybe it's 10V at 1mA and we could suggest a 2N3904...but then
we'd have to assume it's an NPN transistor.
Bottom line is that SOA might be the defining parameter.
The original question is UNANSWERABLE. It tickles me when educated
people make random assumptions then proceed as though they have the
answer...then more educated people jump in to defend it. The internet
tickles me a lot...
Are we having fun yet?
mike
Jamie
mike
this function.
E
ehsjr
Bob said:
Hi, all,
company?
Thanks,
Part # 497-2638-5-ND from Digikey is one you might like.
It's 800 V at 4 amps for $1.68
Dunno if it will work for you, but it answers the question
as asked.
Ed
E
ehsjr
Bob said:
I have checked it after you, however, it is too expensive for me.
Thanks anyway.
That's a bummer. What is the price range you can afford?
Ed
E
ehsjr
Bob said:
1,500k/month.
They (497-2638-5-ND) are .70125 per in qty 10,000 - still too high.
But 497-3510-ND is .50000 in lots of 10,000, and is rated 12 amps
at 900 volts. It might work for you, but they have only 1,989 in
stock.
http://www.digikey.com/
Ed
mike
Bob said:
1,500k/month.
At a million and a half units a month, you should have
vendor application guys flying in to help you design it.
mike
