I intend to connect the brown (live) and blue (neutral) wires comprising the primary input of a toroidal transformer to a fused 3 pin plug.
When I plug it into the mains, I expect the secondary wires (coloured yellow and red and black and grey respectively) to output 2 x 35v AC.
Then I intend to connect the ground or earth wire (here in the UK it will be a green and yellow wire) from the mains lead directly to the metal cabinet of my home brew amplifier (which requires a 2 x 35v AC power supply).
This is the first time I have made a hot device so I am a little anxious about it.
Aside from testing the secondary outputs (very carefully with a DMM) once I plug in the transformer (taking into account that the voltage output could be highly dangerous if for any reason I have got the primary and secondary the wrong way round), should the device be entirely safe provided I solder the ground/earth wire issuing from the mains lead to the metal body of the amplifier cabinet.
Have I missed any safety issues here or should it be safe to proceed here with great caution?
Sincere thanks in advance for any responses.
