In what way toroidal cores are important for heavy transformer ?
Just a school assignment has been doing research on toroidal cores and electromagnetism. While looking for my answers this website just popup straight in between. BTW have been going through forum have found some great answers here. I would like to know in what way toroidal cores are important for heavy or any transformers? Share your thoughts.
Toroidals can be 10% or more efficient than an E I (laminated) transformer.
They can be smaller and still have The same output as a much heavier laminated transformer.
The internet has a wealth of information. Have a very good read.
Martin
One very important advantage of Toroidal transformers is their very low (small) external field which makes them perfect for use in audio systems. I also find it easy to add extra windings to provide low current ±15V for control circuits obviating the need for another transformer.
I have preferred Toroidal's for mains transformers for some years now, mostly for the advantages already mentioned.
Adding over-winds etc, usually around 2 turns/volt.
One thing to watch for that some have made the mistake of doing is to make a cover or clamp to chassis secured by the centre mounting bolt.
If the clamp or cover reaches the bottom of the chassis, this essentially creates a shorted turn and over heating results.
M.
