Hi guys,
I have a buffer amplifier that has a single rail supply of 5v.
Suppose I have an analogue signal as the input signal to the buffer that sometimes exceeds 5v (0v-5.5v)
So in this case, ideally the output voltage won't exceed 5v and clipping/data loss will occur.
Since this is a problem. Is there a method to track the input voltage to determine if it exceeds 5v and have the output scaled down so it will not clip but at the same time have a maximum output signal?
Any help is appreciated!
