Hi:
Lets say that the electrical resistance of my adipose tissue was -- for
some mysterious reason -- decreased from what it is right now to about
10 ^ -500 ohm.
What symptoms would I experience if an AC electric current of 1,000
amps, 50-60 Hz was applied directly to the adipose tissue of my abdomen
via insertion of an extremely sharp electric needle that is only one
iron-atom wide at the end, and which -- for some unknown reason -- also
has a resistance of only 10^-500 ohm? Thermal injuries are out of the
question because of the extremely low resistance.
My guess is that the pressure of the electric current would rupture the
adipose tissue covering my stomach. Am I right?
I would expect resistance of the tissue in a small area/volume
surrounding the needle to experience high current density and high power
density and give all sorts of burning symptoms including great pain and
also electric shock sensation. The resistance of the tissue around such a
small needle with even a tenth or two of an amp can result in significant
burning, maybe to the point of charring and production of bad-smelling
smoke. I think that a kiloamp through an ideal needle would vaporize
surrounding tissue so severely as to cause a blast leaving behind a crater
surrounded to at least a little extent by 3rd degree burns. And with the
current needing to flow somewhere, I don't expect damage outside the
crater to be limited to a little overdoing of a cauterization of the
crater.
Oh, did you say 1,000 amps? Should that have pegged my trollometer? I
have a suspicion that those sent to "The Chair" don't conduct that much
current!
Worry about cooking all regions of the body conducting that much
current, probably in just seconds! Also worry about disruption of the
heart (either ventricular fibrillation or with higher current cardiac
arrest, although sometimes a higher current jolt achieves merely a
"reset").
Don't expect to recover your needle even if it was superconducting.
Expect conducting high temperature vapor around it (as in big fat electric
arc) to do a lot of damage. See what a 1,000 amp welding arc does
sometime - most welding arcs are only hundreds of amps and I have seen
cheaper arc welders rated only 50 amps.
- Don Klipstein (
[email protected])
