What can I say? I drink too much!
There is however a serious part to all of this. A few years back I actually tried building my favorite Williamson amp with J-FETs (BF245A). I actually copied it. And it all worked well except for the "Cathodyne stage" which means that I could not connect the drain of the first transistor
directly to the gate of the next. It was somehow impossible. But inserting a capacitor made it work excellently. I think I even built the push-pull driving stage with BF245As and no distorsion whatsoever was visible on my scope. Then I don't know what I did but I think I tried using two 2SK175 and hooked it up onto some mains transformer which of course did not work.
The interesting part is however that up to the actual push-pull drive of the power MOS, the signal looked very good!
To me it is kind of sad that power MOS are not available in depletion mode. Which means that I cannot use Williamson bias.
The thought of building such an amp has reappeared in my mind due to the simple fact that I am about to design a couple of small loudspeakers and I want to be able to demonstrate them at work without the need for a car to transport one of my superb Williamson amps.
I have put some more thought in the output transformer (OPT). My thought now is to buy a discrete transformer assembly and wind some 100 turns manually for both transistors and some 100 turns for the secondary (abandoning the information in the picture). This way I will probably get more than
wl*L=2*pi*7>4Ohm=>L>100mH
But most importantly, I will still run the output FETs in Class A which means that the transformer need not handle any DC-curents (and thus air-gaps).
Roughly speaking I will then have a quisent dissipation of
P=12*1,5=18W
Considering push-pull and the I/V-characteristics of a MOS then some
Pout~10W
would not be impossible.
The only thing that is really boring, as always when it comes to semiconductors, is the cooling arrangement. Using tubes you never have to consider that.
Finally, there will of course be some feedback applied also. I mean, we are talking semiconductors here. I will use feedback around the OPT and add my original push-pull driving stage to get some raw amplification which I think is needed.
Thank you both for replying to my stupid thread
Best regards, Roger
