Dunno.
I think DMP has an Uplink/Stealth that reports fully from the 100 & 500
panels but I've not used it yet.
Actually, I'd never really noticed the serial port on the AnyNet till this
thread ... gettin olde me thinks.
| I've been told the AnyNet supports the serial output from the NX-8E
although
| I don't have any info on it
| | > Not sure why you'd need serial port.
| > You're gonna run into similar problem in that Uplink only sells service
to
| > alarm dealers though.
| > | > | Hmm.. I had a bad feeling about that when I was reading through the
| > | documentation at the Honeywell web site (I notice the ECP bus wording
| > | but wasn't sure what that meant since I really only know about Caddx
| > | systems.) Ideally, I really would like to have a full CID solution
(for
| > | obvious reasons) - I knew it was too good to be true! Thanks for
| > | replying.
| > | I'll probably need to look into an Uplink AnyNet solution then. The
| > | biggest drawback I see with this approach is not only will I have to
| > | buy a NX-584 for a second serial port (since my first one is used),
| > | I'll have to build a custom cable to hook them together (unfortunately
| > | Uplink doesn't even include a standard serial cable.)
| > | At this point I'm almost considering getting a PhoneLabs Dock-n-Talk
| > | module and use a regular cell phone with a reduced monthly service
plan
| > | this way it will run both cellular (if the land line has been cut) or
| > | land line (primary). It's sad - I know.
| > | > On 23 Jan 2007 14:19:28 -0800,
[email protected] wrote:
| > | > >Does anyone know how the Honeywell AlarmNet 7435-GSM unit would
| > | > >interface into the Caddx NX-8e panel? It's not too clear to me how
| that
| > | > >hook-up would be accomplished (there doesn't seem to be a lot of
| > | > >documentation on the Honeywell site on installation information
that
| I
| > | > >could find at least.) Also, would the connection provide full
Contact
| > | > >ID reporting?You won't get full CID reporting with Alarmnet and a
GE
| > panel. It can
| > | > only be used in 'zone' mode with panels without a Honeywell ECP bus.
