Sylvia Else
You're not with Telstra?
No. The phone is via Optus cable, as is my Internet service.
Sylvia.
terryc wrote
Its always in the part I can fix.
I wired the entire house myself and got an electrician to say he had done it.
How much did you have to pay him?
Dunno how much they charge, but it's legal. The electrician takes on the
workmanship 'guarantee' and puts his stamp on the meter (at least that's
how it was a while ago) as signoff.
I've done 200A industrial wiring that just needed to be looked at and
signed off by the sparky. Good systems in place on industrial sites,
nice big padlocks holding the power switch off.
Lotsa people do their own house wiring and only get caught out after the
place burns down and it gets looked at -- oops no insurance cover...
Grant.
Sylvia said:In NSW, at least, it does not appear to be legal
http://www.austlii.edu.au/au/legis/nsw/consol_act/hba1989128/s14.html
unless the sparky is on site and available for consultation while the
work is being done. It appears that a householder could do some of the
work while the electrician he is employing does another part,
How does that come about under section 14?
Heavens! In my early days I could never afford an
electrician and their lazy apprentices. I soon learned the
basic tricks:
work while the electrician he is employing does another part, but it
would not be lawful to do the work first, and then get the electrician
to look at it later.
From a safety perspective, and as long as the electrician really does
look at the relevant parts of the work, I can't see what difference it
makes, but that's how I read the law.
Employees don't give "directions" to employers. Employers do give
directions to employees, but that is not the factual context. I don't
see how subsection 14(2) can apply in this factual situation, and I
imagine that a court would be very reluctant to give section 14 a
broader construction contrary to what the legislation is about.
Sylvia said:The electrician and the person would not be in an employer/employee
relationship in the normal sense, such that the employer can give
directions to the employee. The relationship in question would be that
of an person contracting to perform a particular service for another.
If the nature of that service includes performing the function of a
supervisor for the purposes of the act, then I can't see any
difficulty with that.
The legislation is generally about ensuring that work is competently
done, mainly in the interests of safety, and it seeks to achieve that
goal by requiring that persons qualified to perform the work are
involved in it. Yet section 14 clearly envisages that some of the work
will be performed by persons who are not qualified to do it completely
on their own.
Further, that section envisages two levels of
supervision, depending on whether the person doing the work has a
trade certificate or not. The greatest level of supervision is required
when the person
doing the work is essentially a layman,
but even there it does not, in
my view, require that the supervisor be close enough to the work to
watch while each and every element is performed.
Indeed, such a
requirement would make a nonsense of the sentence in brackets in
14(4)(a).
Just for good measure, and in the same vein, it appears from this definition
http://www.austlii.edu.au/au/legis/nsw/consol_reg/hbr2004219/s11.html
and the associated sections of the act, that on a proper construction,
one cannot even change/clean the dust filter in one's airconditiong
system, but must call in a tech to do it.
Now, anywhere but Australia, one would question whether that was really
the intent, but these days, Australians seem to be prohibited from doing
pretty much anything they're not expressly permitted to do, so a
prohibition against doing something to the dust filter seems entirely
plausible. Unlicensed breathing is still legal, for the time being.
Crazy -- and there's no guarantee the tech will do a proper job either.
We still allowed to run a vacuum cleaner?
You remind me of another silly new law, that I'm no longer allowed to make
my own ethernet cables?
the tool to reterminate faulty storebought cable, I'm certainly not going
to buy cables that are worse quality than ones I can do myself. Though
my localnet's been shrinking down from eight to five machines, lots of spare
cable running around. But then, I'm renting, so none of it is permanent
wiring.
I know I can do what I like this side of the power plug, too. Or did that
change?
Peter said:These laws are contrived by insurance companies so they can
weasel out of paying every time.
Just think how many house fires are caused by people trying
to by-pass electricity meters, especially these days.
Is it true that if one rotates a water meter 180 degrees,
and it runs backwards, then the council pays YOU?
It is completely true, but only when you are pushing the water from your
premises.
Is it true that if one rotates a water meter 180 degrees, and it runs
Sylvia said:If you both reverse the meter, and push water from your premises, then
the water supplier will charge you for the privilege.
To get the meter
to run backwards, if it's capable of it, you have to do one or the
other, not both.
I'm never game to do anything that can be that easily found out, and
bypassing the meter has to be done carefully, 'cos the power company
knows how much is going into a street, long term usage for each property,
and it doesn't take long to check with a clampmeter on a pole where the
power's going.
Possibly more fun will be had with the new smart meters, we (Vic) getting
them within next four years, but they already upped the power bill heaps
to pay for the rollout.
Be interesting to see how power usage changes, if ones knows what the
current going rate is at any time.
That would be fraud. The water supplier is not supplying water at all.
The meter doesn't work backwards like that. If it did, it would only
reduce the metered amount of water being supplied by the water supplier,
but not provide a way to calculate the water being supplied to the water
supplier.
