Nemo
I have a high capacitance photodiode (650pF with as much bias as I can
put on it) which I want to measure at high gain and 100kHz bandwidth or
more. It works well enough to meet spec, but I'm trying to make it
better simply to learn more about analog design. Simply using a TIA to
amplify it by about 1M - I'm trying to get as much gain in this first
atge as possible to reduce Johnson noise in the feedback network - I get
minor oscillations at around 100 - 150kHz unless I increase the feedback
C to a point where my bandwidth is adversely affected. I was wondering
about using a T network to get round this, but my experiments didn't
seem to improve the instability, and I wondered if there was something
obvious I was missing.
I should say first that I rapidly found that there was a lot of DC drift
from using a T, so if doing this on a PCB I would use one where the
elements are on the same chip and had tight tempco matching (Vishay do
some with 2ppm matching, in a SOT23 package. Expensive, but price is not
a concern here.)
The circuit I tried was along these lines:
_____1 - 3pF_____
| ___100k_______|
i --> --|__|\ |
| \______10k---1k___
0V__| / |
|/ 0V
I reasoned I would be able to use a higher C, maybe 10 - 20pF in
parallel with the 100k to get stability, but maintain the same
bandwidth. But I found that increasing the feedback C to the point where
the instability is reduced, just decreases the bandwidth dramatically,
as if the C is also being multiplied by a factor of 11.
The amplifier is a compound one along the lines Phil Hobbs suggested a
few weeks ago: JFET front end feeding low voltage noise op amp, with
auto nulling circuit servo-ing the input to 0V. I've tried several op
amps of various GBW's and all display this slight ripple in the output.
I concluded that T's are good if you want an unfeasibly high feedback
resistance, but have no bandwidth advantage. But I hope I'm missing a
trick here and you guys will drop a hint 8)
I also wondered what is really meant by a "stable" amplifier. Students
are told "stick more C in the feedback loop to make it stable." Is this
one of those glib simplifications? I'm looking at the output at high
gain and there is always _some_ ripple present if there is significant C
on the input and you turn the gain on the 'scope up high enough. Surely
there will always be SOME degree of chase-your-tail hunting round the
feedback loop for any amplifier? Or is it possible to get a TIA which is
actually truly stable with this kind of C on its input?
Nemo
a concern here.)
_____1 - 3pF_____
| ___100k_______|
i --> --|__|\ |
| \______10k---1k___
0V__| / |
|/ 0V
Nemo
