amdx
I have a 4 volt pulse that is 0.5 sec long.
I need a 6 sec pulse that will switch a 2n3904.
The 4 volts has about a 400 ohm source impedance.
I could use a 555, but first I need to invert the signal then
drive my 2n3904 switch, so I have 2 transistors and a 555. Oh yes I
could probably differentiate the 0.5 sec pulse to trigger the 555, so
maybe only 1 transistor and a 555.
Could someone help with a pulse stretcher circuit.
Maybe an RC, transistor, or, I have some FETs, J301 or 2N3819, probably
a diode. That will drive my final 2N3904 switch.
The 2N3904 switch is across the alert button on a Walkie Talkie and
shorts about 3.5v to ground.
The longer story;
This started with "Have 5v regulator need 9 volts"
That particular problem is solved. everything has good clean power.
I have a Harbor Freight *Driveway sensor.
The sensor triggers a receiver with RF.
The receiver in turn triggers the alert button on a **Walkie Talkie.
After a temporary install, I noted the Talkie alert signaled 10 times.
That is to much, three times is fine.
After trying several things to eliminate the 10 alerts, I finally
wrapped the walkie talkie in aluminum foil. Problem solved. I'll deal
with this later by putting the Harbor Freight receiver inside my boat
and the walkie talkie outside where it's RF can get out. (it's an all
Aluminum boat)
The 0.5 sec pulse causes one alert signal. A six second pulse causes
three alert signals. Perfect!
http://www.harborfreight.com/wireless-driveway-alert-system-93068.html
http://www.motorola.com/Business/US...umers/Talkabout+FV300+Two-Way+Radio_B2B_US_EN
Mikek
The longer story;
Aluminum boat)
Mikek
