I decided to try to build this and have it all breadboarded up.
https://www.youtube.com/watch?time_continue=819&v=oRhO0MJIl58&feature=emb_logo
The schematic for it is at 6:50 of the video.
It is a Theramin- which is a musical gadget of sorts. It makes zany noises when your hand moves toward it.
To see Lez Zeppelin use, one, see 6:15 of this videohttps://www.youtube.com/watch?v=JoTyCwRkm3I
In any event, in the video, the builder of the circuit uses a TIS58 JFET transistor (which has long been discontinued).
I am using a MPF102 JFet instead. As the maping between what he used, and mine is slightly different, I adjusted my wiring accordingly. More specifically, in his JFET, the ordering is Drain, Source. Gate. In mine, it is Drain , Gate, Source.
So I very carefully put all this together, and used flar coinnecting wires when I could, so as to keep the breadboard tame.
But, surprise, it's not working.
Any ideas on what to check? I have include pics of my breadboard but I realize it is not easy to look at pics.
Some of the things I am wondering about. I pulled a telescopic antenna from an old mid sized transistor radio i had. The antenna seems to only have one lead coming out of it. Could the antenna be the issue?
In order to keep things withing reasonable cosyts, i ended up buying these variable capacitors:
https://www.amazon.ca/gp/product/B07DDHV5V6/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1
I think they are intended for Audrino, but they should work regardless right? They did not have the exact spec the ciorcuit calls for- it calls for a 4-50pF. The ones I ordered had a 40pF and a 60pf- but not a 50pF. I chose to use the 60pF.
Any thoughts?
Thank-you
Any thoughts?
Thank-you
