mw
Is there a book or link that gives some hints on properly designing a pc
board so that it works well with ~100 VDC on the traces? I think that
having this high voltage on the pcb will cause a break down of the board
material (after several years). I want to prevent this. Is it as
simple as using large spaces between the traces? Using conformal
coating or varnish? Or is there a material other than FR4 fiberglass
that is available?
Also, I will want to attach a big transformer to the pcb and I know it
is bad to run wires directly into a pcb because the solder can be
brittle and this will cause the wires to be weak. It's also a hassle to
unsolder for repair (the traces get ruined due to solder gun heat). So
is there a terminal or "turret" like on tube amplifiers that can be used
to protect the pcb? Or maybe this is a lot of worry about nothing. But
I do want my power supply project to last for several years.
Any ideas for a simple wire terminal to save the pcb? I don't want to
use a connector because they can go bad after several years. Soldered
connections seem simpler and more robust for longevity.
that is available?
