Stage Line 500W amp repair project
did notice this when i seperated R172 and R174, thay look to be slightly burned where they were touching, seperated them before i turned it back on and the fan started working!
Maybe the fan should have kicked in normally in a fault condition and this was stopping it. I don't think it's related to the fault LED.
Adam
No it's ok. When we say lower and upper end it's looking at the diagram the way it is drawn. The upper end is nearest the top of the drawing, so the supply. The lower end is the other side of the resistor where it connect to the base of the transistor.
Edit: Lower end or bottom end
OK, R177 is in a different part of the circuit. If Q46 collector is still 0V there is still the same problem with that part of the circuit. Have a close look around R108. There's something strange going on there.
What's the +45VL voltage that Adam asked for?
Where am I mesuring for for this,
Is it The top end of R108 and T4?
Another thing is turn the power off and measure the resistance across the emitter terminal and the base terminal of Q46 with leads both ways around. That's from the label marked +45V (Not +45VL) and the lower end of R108.
Adam
ah think i understand now, the messages are all over the place,
do you want me to test the marked points in the diagram in post #203?
with the transistor installed and the amp powered off?
ok meter set to 2000 in the Ω range,
red probe on emitter of Q46
black probe on the base of Q46
meter reads 555
black probe on emitter of Q46
red probe on base of Q46
meter reads990,
do you want me to test Q46 the same way out of circuit or test the board where Q46 should be once removed?
also do you want me to test from emitter to lower end of R108, or base to R108
red probe on emitter, black on the bottom of R108
meter reads 554
same test oppersit way round
meter reads 988
both tests with Q46 installed
red on emitter point on the PCB
black on the base point on the PCB
meter reads 989
same test with probed switched
meter reads 989
black probe on bottom of R108
meter reads 988, with probes both ways round
Ok so looks like the transistor is not causing any issues here. This is really puzzling now, how can you measure 0 V across R108 when it should be dropping approx. 3 V. Ahhhh! this is doing my head in. For the same voltage to appear across R108 then it must be coming from somewhere.
Adam
