Prove it, Rat_Bastard. Otherwise, STFU.
Here is ONE:
Path:
aioe.org!eternal-september.org!feeder.eternal-september.org!.POSTED!not-for-mail
[email protected]>
Newsgroups: sci.electronics.design
Subject: Re: Schematic layout conventions
Date: Wed, 27 Apr 2011 00:00:25 -0500
Organization: A noiseless patient Spider
Lines: 22
Message-ID: <
[email protected]>
References: <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]> <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
Mime-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
Injection-Date: Wed, 27 Apr 2011 05:00:28 +0000 (UTC)
Injection-Info: mx02.eternal-september.org;
posting-host="R1JcZqQrnJVzF0KrDRtdjQ";
logging-data="21266";
mail-complaints-to="
[email protected]";
posting-account="U2FsdGVkX19k99MKT69QhwWntK1Fv/QR"
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.15)
Gecko/20110303 Thunderbird/3.1.9
In-Reply-To: <
[email protected]>
Cancel-Lock: sha1:TcsZLNiUu+cEDgFUXVRmR+mMh/k=
Xref: aioe.org sci.electronics.design:165826
I used to put cutting data into a VAX for a set of three plasma
cutters, (around 1990) all cutting stainless, for institutional
(hospital) and government fully welded HVAC ductwork.
It would 'nest' all the pieces we entered such that the minimum scrap
was generated. Plasma moves a bit faster than flame, and the stock is a
lot thinner, of course.
The robot had to be calibrated for flame tool speed, and the cutting
probably had to be real time monitored by someone with a kill switch
because torches sometime stop cutting and simply flare wide.
"Probably"? You don't know? This is another piece of dreamed-up pile of
crap by AlwaysWrong.
HERE is TWO: (this is YOU mentioning someone else mentioning it)
Path:
[email protected]>
Subject: Re: Stability of older Orcad/PSpice combos?
Date: Thu, 28 Apr 2011 20:48:04 -0500
Lines: 75
Message-ID: <
[email protected]>
References: <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
Mime-Version: 1.0
Injection-Date: Fri, 29 Apr 2011 01:48:09 +0000 (UTC)
logging-data="11561";
[email protected]";
posting-account="U2FsdGVkX1+20G+drPfhwSTaoj+XVJJT"
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.17)
Gecko/20110414 Thunderbird/3.1.10
In-Reply-To: <
[email protected]>
Cancel-Lock: sha1:j6Uu551GB1Tm64NOmeImu0GOi44=
Xref: aioe.org sci.electronics.design:166255
Jim said:
John Larkin wrote:
On Wed, 27 Apr 2011 22:51:59 -0500, "
[email protected]"
On Wed, 27 Apr 2011 17:06:50 -0700, John Larkin
On Wed, 27 Apr 2011 18:00:29 -0500, "
[email protected]"
josephkk wrote:
Looking at this again, i suggest that you have some version of DLL hell. I
do not have any problems with Acrobat on any machine, Windoes or Linux.
This is often the root cause of Flash problems as well.
Why is Foxit stable then and Acrobat isn't? And Cadsoft Eagle is rock
solid and Orcad isn't? No matter how impatient I am (and with software
and GUIs I am not the most patient guy) I have not managed to bring
Eagle to crash on me. I can bring Foxit to choke and huff and puff, but
not really into a CTRL-ALT-DEL situation.
I should think that's obvious. Neither Foxit nor Eagle have DLLs with
conflicts. In fact, this points to conflicts between Orcad and Acrobat.
No Acrobat, here, and I can get OrCAD crashes quite consistently. Fewer with
16.3 than 15.7 but it'll still crash. When it does, it's more often without a
save, now.
Does it have periodic autosave? PADS does.
It causes crashes.
Oh.
Yep. Found that out the hard way. Now that I have set auto-backup to 300
minutes (essentially meaning never because by then I am on the next
schematic) the number of crashes is lower. I also learned to smell
wooziness and do a quick shut-down. For example when placed probes
refuse to turn from gray to some bonbon color.
I hope you're backing up to other media. ...
Oh yeah, three different media. With Orcad me no take no chances no more
... Your ass is about to be grass ;-)
What, you had that turning gray of probe pins happen, too?
No, Remember I don't use Crapture, but can convert my schematics to
Crapture upon request... without ever opening Crapture ;-)
The word "crapture" has become trite, especially when used three times
in one sentence.
Please, Jim, tell me you're not developing a feces fetish like your most
recent admirer.
HERE is THREE:
Path:
[email protected]>
Date: Thu, 28 Apr 2011 21:16:26 -0500
Lines: 51
Message-ID: <
[email protected]>
References: <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
<Vy%
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
Mime-Version: 1.0
Injection-Date: Fri, 29 Apr 2011 02:16:32 +0000 (UTC)
logging-data="29805";
[email protected]";
posting-account="U2FsdGVkX19FPHPRtox46493IwBOdkqI"
In-Reply-To: <
[email protected]>
Cancel-Lock: sha1:Tu9BHe2FjShlSY6y0mPx/DKGrAM=
Xref: aioe.org sci.electronics.design:166263
John, YOU are the hen here.
You got miffed when the roosters came out and cockled about your
mistake, and YOU began clucking and have yet to cease.
You are WRONG, John. You also indicate to the ENTIRE world that you
ignore standards and conventions at every turn. You even declared such.
That is pretty much the epitome of the definition of the word
"pathetic", John.
You are uneducable.. Sadly, not because you are stupid, but because
you choose to ignore the world for your "Larkin's Rose" colored view of
things.
You could not be more incorrect. You are busted.
I guess that settles it, John. The "Rat" has spoken. It must be so.
Since you are "busted", according to the "Rat", will you now turn
yourself in to the "Faux Pas" police? I am sure that the sewer "Rat"
will not give up until he drowns in his own excretions.
HERE is FOUR:
Path:
[email protected]>
Date: Thu, 28 Apr 2011 21:21:32 -0500
Lines: 19
Message-ID: <
[email protected]>
References: <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
Mime-Version: 1.0
Injection-Date: Fri, 29 Apr 2011 02:21:36 +0000 (UTC)
logging-data="30666";
[email protected]";
posting-account="U2FsdGVkX1/vS/eMvwMtt0dhRI9mSEtK"
In-Reply-To: <
[email protected]>
Cancel-Lock: sha1:gAGzQYeeYJ/bjDZBPSis6kJyekk=
Xref: aioe.org sci.electronics.design:166267
This is typical Larkin horseshit.
He goes from declaring that I have no math ability whatsoever, without
a shred of evidence, to this dumbed down version of the same insult
attempt.
All because the retarded bastard might have to admit that
I was doing math before he knew what math was.
How about a demonstration of your math prowess, you lying piece of shit?
HERE is FIVE:
Path:
[email protected]>
Subject: Re: 4-20mA Precision Source Ideas - print.pdf (0/1) - print.pdf
(0/1)
Date: Thu, 28 Apr 2011 22:48:24 -0500
Lines: 18
Message-ID: <
[email protected]>
References: <
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
[email protected]>
Mime-Version: 1.0
Injection-Date: Fri, 29 Apr 2011 03:48:29 +0000 (UTC)
logging-data="22558";
[email protected]";
posting-account="U2FsdGVkX1/+scWRDYRVvJZNXwIms3+4"
In-Reply-To: <
[email protected]>
Cancel-Lock: sha1:Cx5Xa5vaRFMfze01S+2IgCeYrBo=
Xref: aioe.org sci.electronics.design:166286
"such as it is"
I smell a retard in the thread...
No, your head is so far up your ass that you can smell nothing else but
your own excrement. After a while, your brains were replaced with your
excrement by osmosis. Hold your breath from now on, shit-for-brains.
YOU LOSE, JOHN KD5YI.
Your fetish has been exposed. You cannot escape, since the criteria is
the same for everyone.
