Charlie E.
No, you don't owe me
As one SW engineer once said after he helped me out of a pickle, "We are
all here to serve".
Let's just say I would be glad to give you advice then... ;-)
Charlie
all here to serve".
Joerg said:Had to work on the weekend because of these dreaded crashes, so no time
for the PC to do that. But I doubt there is a problem. There are only
two programs that notoriously crash: Orcad and Acrobat, and Acrobat got
kicked out which solved that problem. Dozens of other software companies
whose SW is on this PC must have done something right because theirs
does not crash ;-)
Charlie said:Actually Jeorg, it almost sounds like you have multiple versions
installed, in different locations, and the registrations keep getting
futzed up. You might just try to run each of the applications
individuatlly directly from My Computer, as this will self-register
teh applications. I used to have a batch file that ran each exe with
a registrations keyword, but can't find it now... :-(
Nico said:Grant's suggestion is a good one. In many cases a memory error
surfaces by using a particular application while the rest seems to run
just fine. I recently used memtest succesfully to find a defective
memory module.
Jim said:Is that Mormon or Catholic or Baptist "rite" protected? It'll make
difference![]()
Lutheran. Of course![]()
Michael said:That's an understatement.
Revo will let you remove all traces of a program from the hard drive,
including things that are buried in the registry. I use it to clean up
donated computers. Some programs have over 3,000 registry entries that
aren't removed by using the uninstall routine that comes with the
software. You load and run Revo, then click on the program you want to
delete. Click 'Uninstall', and the built in unistaller runs the
program's unistall routine. Then click 'next', and 'delete' as prompted
to clean up the registry and remove empty folders. ...
Michael said:Your igonrance is showing.![]()
And you have no clue how to recover that first so you keep wasting by
time reinstalling it, over and over. That's called insanity.![]()
Michael said:Whatever. It's still a huge waste of time.
I have Sun VirtualMachine on here. But Cadence's license model is IMHO
highly complicated and cumbersome, I doubt this would work.
does not crash ;-)
Michael said:Times how many hundred reinstalls?
Looking at this again, i suggest that you have some version of DLL hell. I
do not have any problems with Acrobat on any machine, Windoes or Linux.
This is often the root cause of Flash problems as well.
Why is Foxit stable then and Acrobat isn't? And Cadsoft Eagle is rock
solid and Orcad isn't? No matter how impatient I am (and with software
and GUIs I am not the most patient guy) I have not managed to bring
Eagle to crash on me. I can bring Foxit to choke and huff and puff, but
not really into a CTRL-ALT-DEL situation.
How come virtually no one else has these problems?
You ought to cleanse your whole machine, then reinstall everything.
But you won't :-(
Jim said:Oh they do. I've heard that from many engineers. Just ask Keith about it ;-)Jim said:josephkk wrote:
That's one ;-)
Crapture? Certainly! Why do you use it? I already told you how many
times that the native PSpice Schematics is marvelous, plus presents a
trivial few key clicks to produce a Crapture copy if the client
requires.
Foxit, CutePDF, Irfanview, PADS sch+pcb, CrimsonEditor, Firefox,
Thunderbird, PowerBasic, LT Spice, Appcad, TXline, RFsim99, all seem
solid.
We wrote our own parts database program. It's in its third iteration
now. The same database file has run uncorrupted for about 15 years
now. Because it's simple.
Jim said:[snip]If I need to do more of these jobs I'll probably get PSpice Schematics.
There are free copies in circulation. Take it for a spin.
I should think that's obvious. Neither Foxit nor Eagle have DLLs with
conflicts. In fact, this points to conflicts between Orcad and Acrobat.
No Acrobat, here, and I can get OrCAD crashes quite consistently. Fewer with
16.3 than 15.7 but it'll still crash. When it does, it's more often without a
save, now.
Does it have periodic autosave? PADS does.
John said:It causes crashes.On Wed, 27 Apr 2011 18:00:29 -0500, "[email protected]"
save, now.
Oh.
