SSB Antenna Installation
bradleyj
I am going to be installing a 23' whip antenna for a new SSB radi
installation on my boat. My vessel is all-aluminum construction with
center pilot house. How would you suggest mounting this antenna on thi
vessel? I understand that it is important to keep the whip from comin
too close to any metal. This is an obvious problem, since this boat i
all aluminum. Any suggestions or references would be appreciated
Lynn Coffelt
I am going to be installing a 23' whip antenna for a new SSB radio
installation on my boat. My vessel is all-aluminum construction with a
center pilot house. How would you suggest mounting this antenna on this
vessel? I understand that it is important to keep the whip from coming
too close to any metal. This is an obvious problem, since this boat is
all aluminum. Any suggestions or references would be appreciated.
Well, I don't know if you are talking about something like a metal
Morad WH-23 or a fiberglass 23' Shakespeare or equivalent, but both need a
two piece mount. Probably some swivel bottom mount so it can be laid down at
times, and an upper support mount at least two feet up from the bottom.
Placing these two mounts as high as possible on the metal side of the pilot
house is fairly common. If you really want to gain all that length above the
pilot house, a fabricated aluminum tripod or sturdy welded post about three
feet high is cool.
The lead-in from the antenna to the tuner should be almost all outside
the aluminum pilothouse. Lots of boats (and ships) put the tuner outside the
pilothouse, near the antenna base to avoid any lead-in inside the
pilothouse. If you do the latter, very careful attention to sealing of the
coupler, and if you elect to vent it (Usually a plus), be sure the vent hole
is where the manufacturer recommends (at the very bottom, of course).
It would make suggestions a lot easier if you could post a picture or
drawing of your boat.
Tell us when you test so we can listen and report!
Old Chief Lynn
Larry
You're very lucky, as HF operators go. The metal boat will make an
excellent "ground plane", the counterpoise plastic boat owners dream of.
What kills HF is any PARALLEL metal which the RF waves intercept on their
way out of the boat. This actually creates a capacitor, its two plates
being the mast at boat ground and the whip, with the air as its
insulator, thus shunting the RF energy off to ground. Two feet is not
enough, infinity is. The further you can get the whip away from any
metal rising over it, the better. The best place is atop the mast with
the whip sticking way up above it, but this isn't very practical as
you'll be going under overhead obstructions. So, let's mount the whip as
far away from the mast as we can get, including its guy wires and other
metal/wire/conductive things going aloft.
Let's put the base for the whip on TOP of the nice metal pilot house
ground plane (which ends up perpendicular to the whip). This makes USE
of the excellent ground plane effect of the horizontal pilot house roof,
while keeping the E-field from intersecting it.
PLEASE DO NOT MOUNT THE WHIP ON THE SIDE OF ANY METAL HOUSE if you can at
all help it. The shunt capacitance of the whip near the wall of the
pilot house exterior mounted for convenience on the side somewhere is
just awful...sucking your signal off to that metal along side the whip.
Signals suck like that.
You didn't mention a flybridge atop the pilot house so I'll assume you
don't have one. So, let's mount the whip dead centerline of the pilot
house roof, about a foot from the forward edge of it, with the
weatherproof tuner right next to it. The tuner's output wire to the whip
should be as short as you can possibly make it as that becomes part of
the antenna (and part of the shunt signal off to metal problem).
The ideal mount would be a hole in the pilot house roof with an insulator
mounted THROUGH the roof with the tuner mounted safely INSIDE the pilot
house right next to where the feed-thru mount's "hot" bolt protrudes
inside. Of course, though I'd be proud as hell of it, myself, the
yachties would scowl, seeing the tuner overhead of the pilothouse...(c;
Be sure, wherever you mount the whip/tuner to put a heavy metal stainless
strap from the tuner's ground bolt to the BARE METAL under the closest
leg of the tuner where it's bolted to the pilot house roof, a fantastic
ground.
I'm green with envy. Lionheart has a long strap ground to the engine
block...the only metal mass of any consequence in the plastic ketch....
(sigh).
Larry W4CSC
Lionheart WDB-6254
Icom M802, Icom AT-130, 55' long insulated backstay....poorly
grounded...dammit.
Gary Schafer
ground.
(sigh).
Larry W4CSC
Lionheart WDB-6254
grounded...dammit.
And just how would you recommend supporting that 23 foot whip mounted
on top of the pilot house?
regards
Gary
Larry
regards
Gary
Shrouds?....(c;
The discussion was about where to mount the antenna for best radiation.
There are many antennas and mounts that require no cheap little plastic
support like Shakespeare uses on their antennas.
What I'd like to see mounted on top of his pilot house is an antenna like
the Moonraker 18B, with a proper, supportive deck mounting:
http://www.moonraker.com.au/marine.htm#MFHF
Click on 18B for the PDF file. Get the untuned version.
I'd mount this antenna THROUGH the cabin roof so it comes out in the
overhead panel or a cabinet with the tuner mounted out of the weather
inside the pilot house inside the panel. We have no pictures of his
pilot house so we can't see where that might happen. With the tuner
inside the boat, it'd take a direct lightning hit to destroy it, not
seawater. No cables, connectors, wires only the whip would be in the
weather, solving the big corrosion problems completely. This antenna
mount is designed to do just that, feeding the RF through the roof into
the dry tuner inside.
No extra "support" for the bassboat swingdown is necessary....
All this depends on other data we don't have. Where does he go
boating?....Is he going to be going to sea, or is he going up and down
the ditch with all the drawbridges? (If he's not going to sea, there's no
point in HF comms, anyway, so I assume he's going to sea.)....How high is
his mast over the pilothouse?....Does he need a swingdown mount, really,
or are we doing this just because that's the way it's always been done?
We don't have all the data. I was just responding to where the antenna
would be best mounted for best radiation. That's not necessarily the
best for his situation....
bradleyj
Boy, I never expected to get so much great advice so fast!! I'
digesting it all now. I've known since I started looking in to thi
that I'd have an awesome ground plane, but I never gave much thought t
problems I'd have mounting the antenna. I'll let you know how I decid
to go. By the way, I tried to post photos of the boat, but this serve
kept giving me errors. Here's a web site with a picture:
http://www.specmar.com/boatpics/boatpic55.jp
Bruce in Alaska
feet high is cool.
Old Chief Lynn
[/QUOTE]
After looking at the Jpeg of the boat in question, I would like to ask
only one question. What would be the purpose of a MF/HF Marine Radio
Installation aboard this vessel? It hardly looks big enough to do any
High Seas operations, but if one could come up with a reasonable answer,
then Old Chief Lynn, makes a good case for the best MF/HF Antenna
installation for this vessel. All the above not withstanding, understand
that any 23Ft unloaded antenna isn't really long enough to provide
quality communications below about 6 Mhz. Also understand that in order
to fit a MF/HF Marine Radio System, you MUST apply for, and be granted,
a Vessel Radio Station License, by the FCC, as this type of radio is
NOT covered by the Blanket Station License granted to all non-commercial
vessels of US flag. All Radio Operators who use this radio, MUST also
apply for, and be Granted, a Restricted Marine Radiotelephone Operators
Permit. (unless you are operating the vessel in alaska)
Bruce in alaska
Larry
Nice boat, but I would not use a deck-mounted whip since it would be
surrounded by metal: not only by the pilothouse, but by the sides as
well! Instead, consider a 16-foot whip mounted on an insulated support
at the level of the gunwhales and supported at the pilothouse roof.
With all the windows in the pilothouse, I wouldn't give losses a
second thought.
Good luck.
Chuck
I'd recommend not putting an HF SSB radio in this little boat at all. Who
are you going to talk to on it? It's not big enough to take to sea for a
cruise, so why would it need SSB capabilities so close to shore?
I doubt you're going to be able to keep an SSB radio working in this wet
environment. WHATEVER you do, don't buy an Icom! Their SSB radios are NOT
sealed up, at all, having many openings that will simply be filled with
spray and destroyed. It isn't going to happen with a radio like M802 or
702 in this boat.
This boat doesn't need SSB. It needs a full-power VHF into a 6 dB folddown
antenna whip.
Lynn Coffelt
Well! you've reaped some really good information, and some that is,
shall we say, not quite so helpful. It is obvious that a "lay-down" mount is
a good idea, and it looks like the most practical solution would be a
stainless steel "lay-down" or swivel mount at or near the bottom edge of the
aft window, starboard side, with the upper mount just under, or on the cabin
top overhang. Capacity to ground here is not particularly a plus, but it
looks like it could be ignored.
Don't know if marine SSB or Ham radio (or both) is your aim, but
anywhere outside VHF radio range, there is surely no modestly priced
substitute for marine SSB. The 23 foot whip won't make you the "Voice of the
North Atlantic" on 4125, but it should wake up monitoring stations most
times of the day.
Bruce's notes on licensing are worth listening to, particularly if you
wander up into Canadian waters.
Will we all get to share your first catch for our help?
Old Chief Lynn
Larry
I think his money would be much better spent on a GPS-receivered 406 EPIRB
for this little boat's emergency comms, don't you? I don't think he's
gonna be an offshore longliner with outboard motors.
Another good point IS those outboard motors with the heavily-RF-Shielded
plastic covers. I doubt he's gonna HEAR anything but a steady buzz on any
HF frequency with two big 2-strokers using solid wires and straight spark
plugs in all that NOISE!
bradleyj
Thanks again for everyone's input.
To clarify why I am installing a SSB. My boat is a 28' documente
vessel with a fisheries endorsement. I fish commercially as much a
100 nm from shore. Any documented commercial fishing vessel operatin
outside of VHF radio range from shore stations (maybe 25-30 miles on
good day) is required by the Commercial Fishing Vessel Safety Act t
carry a MF/HF radio. I have my FCC ship station license and restricte
radiotelephone operator permit. I also have a 406 MHz Type 2 EPIR
(also required by law) and other safety devices too numerous to nam
(also required by law). All I really need to be able to do is contac
the nearest shore stations. I'm not looking to talk halfway around th
world.
Now back to the installation. I'm leaning toward a guyed installatio
on the pilot house roof. This will get the antenna up and away fro
all metal structures. I drew up a sketch of the concept, but I stil
can't seem to upload any picture files to this server. I'm planning o
going with a Shakespeare 5390 17.5' fiberglass coated whip. I'
thinking of attaching three stainless guy wires about 4' up from th
base. The idea I have for attaching anchors for the guy wires is t
fabricate three aluminum brackets with holes to clip the guy wires t
and installing them 120° apart on the antenna whip by wrapping the
with fiberglass tape and encapsulating with resin, much the same wa
that the eyes on fishing rods are attached to the rod blanks. Th
stainless steel guy wires will attach to three points on the edge o
the pilot house roof. My question is will these metal brackets and gu
wires cause problems with antenna performance (or roast the occupants o
the boat)? The brackets will be electrically isolated from th
conductors inside the whip by the fiberglass coating on the whip, bu
will RF energy still be affected (shunted down through the guy wires t
the pilot house)? Does anyone else have any other ideas?
Bra
Larry
I'm
thinking of attaching three stainless guy wires about 4' up from the
base.
Oops....nope. The guy wires must not become part of the radiator, which
wire will do. The guys should be line, not wire. Use the kind of line
you'd see on a sailboat topping lift and you'll do fine. It's good the
line flexes some as the fiberglass whip is designed to flex some and that
takes the stress off everything.
You can make a 3-point metal plate that will slip over the smaller, upper
part of the whip, but with a hole that won't pass the metal part where it
widens, which I think happens two times on this antenna you're
considering. Slip the whip through the hole and let it seat itself down
the mast with further securing. It isn't going anywhere. The small
metal plate is too small to make any big RF statement on HF. This gives
you a tiepoint for the small supporting, INSULATING, line to tie off to
your cabin roof points. The fold-down mount will then be easy. Release
one line, maybe use a clip on it to tie it to the boat and she'll fold
right over for trailering, which I can see makes my previous fixed
suggestion impossible. Bolt the HF antenna tuner to the top of the cabin
right beside the base so the folding doesn't hit it (port or starboard)
and keep the "hot" lead from the tuner to the antenna as short as
possible.
Be sure to ground the tuner's ground lug to a ring terminal bolted to the
cabin roof, as short as possible, with a heavy strap. Coat the
connections with some grease to keep the water away from them and seal it
up. This ground will make the whole boat the ground counterpoise and
turn the plastic blowboat HF users green with envy for your great ground
plane.
Wouldn't two DIESELS be much cheaper and lots more reliable than outboard
gas guzzlers in a commercial operation???
bradleyj
outboard
Yes, diesels would be prefereable. However this hull was specificall
designed for twin outboards. It has a transom extension for mounting th
outboards. The hull is also pretty shallow, so there's not much space fo
engines under the deck. As for costs, the outboards were MUCH cheaper t
purchase than diesels would have been, especially since I got them used.
These are relatively new direct injected, computer controlled 2-stroke
and the boat is pretty light (about 5000 lbs dry), so I get great ga
mileage; about 2 mpg crusing at 25 knots. What I'd really love would b
a pair of 150 HP diesel OUTBOARDS, but I don't think there's any suc
thing. Having two engines covers me on reliability. I can still mak
over 25 knots on one motor. Full speed at WOT on both motors is almos
40 knots.
One of the earlier posts mentions RF noise concerns from the motors. An
other opinions on this? I could line the motor cowls with aluminum foi
if this would help.
Also, with a 17.5' antenna, at what frequencies would I have bes
performance at? What kind of ranges could I expect? The only reall
important frequency for me is 2182 kHz (int'l distress). I need to b
able to contact local Coast Guard stations (several of which will be les
than 150 miles away at any given time) on this frequency in an emergency
Bruce in Alaska
Thanks agaifor everyone's input.
To clarifwhy I am installing a SSB. My boat is a 28' documente vessel with
100 nm from shore.
snipped for brevity.......
Noback to the installation. I'm leaning toward a guyed installatio on the
pilot house roof. This will get the antenna up and away fro all metal
structures. I drew up a sketch of the concept, but I stil can't seem to
upload any picture files to this server. I'm planning o going with a
Shakespeare 5390 17.5' fiberglass coated whip. I' thinking of attaching
three stainless guy wires about 4' up from th base. The idea I have for
and installing them 120apart on the
rod blanks. Th
the boat)? The brackets will be electrically isolated from th conductors
inside the whip by the fiberglass coating on the whip, bu will RF energy
still be affected (shunted down through the guy wires t the pilot house)?
Ok, now we have just about enough information to make some relativly
speaking, informed observations.
1. A 17.5 Ft unloaded whip isn't going to be much of a radiator in the
MF/HF Marine Radio Bands, below 8 Mhz, no matter what autotuner
you put under it.
2. Just who are you planning to talk to with this MF/HF Radio? Most
of the High Seas Public Corespondence Stations went off the air
a decade ago, so that leaves Private Coast Stations, which may
or may not want to handle your traffic, unless you actually
setup a scheduale with them.
3. You maybe are thinking that the local USCG will actually be
listening to the High Seas Calling Frequencies, and they
actually, may be, but for your operational area, the MF and low
HF Frequencies give the comm's for that area, and your
antenna isn't actually going to preform good enough to allow
resonable expectation of succesful communications.
4. As Larry states, it is a very good thing that you have a 406
EPIRB aboard for Distress Alerting, because if you are depending
on the above MF/HF Radio to save your life, best you get lots
of Life Insurance, and buy a Plot before you go out past VHF
coverage.
5. I suppose you could have a Wx Ballon and Hydrogen Canister aboard
and use that to lift a decent length MF Antenna for Emergency
Communications, but just how well are you going to be able to do
that while in an Emergency Situation.
Yea, Yea I know that the FVSA says you have to fit a MF/HF Radio in order
to be out passed VHF Coverage, in Sea Area A2, but in that area it is
designated that MF comms should be used, and your Antenna System
is going to be more like a Dummy Load, at MF Frequencies than an
antenna.
Bruce in alaska
Larry
These are relatively new direct injected, computer controlled 2-strokes
and the boat is pretty light (about 5000 lbs dry), so I get great gas
mileage; about 2 mpg crusing at 25 knots. What I'd really love would be
Oh, God.....Please tell me they are NOT Ficht engines that you're going to
sea with...Please....
Larry
One of the earlier posts mentions RF noise concerns from the motors. Any
other opinions on this? I could line the motor cowls with aluminum foil
if this would help.
If these are Ficht engines, I doubt you'll ever hear anything, foil or not,
on an HF radio. Hell, they wipe out a 5KW AM on 1250 in the harbor! The
computers and that stupid injection system blowtorch eating the heads off
the spark plugs..all those make incredible RF noise. You'd never be able
to shield it all as it sneaks out every wire going to the console, its own
antenna.
Please tell me those are not Ficht engines....How awful.
bradleyj
Yes everyone, they are Ficht engines. After doing a tremendous amoun
of research on these motors prior to buying them (includin
conversations with mechanics who have worked on them), I came to th
conclusion that the modifications that OMC made to address the desig
defects originally present in these motors did the trick. As part o
these mods, these particular motors were refitted with redesigne
cylinder heads, fuel system modifications and new ECU software. Thes
motors were installed on a NMFS vessel in Alaska for four years. Whe
they repowered their fleet in 2003, I purchased them with about 32
hours on them and put another 100 trouble-free hours on them mysel
last year. I do the vast majority of my fishing within 20 miles o
shore and when I do go offshore, I never go out more than about 10
miles. The chances of both engines failing simultaneously is prett
remote.
If any one of you badmouthing the Fichts has ever owned one and ha
problems with it I'd like to hear your story. I'll be a bit surprise
if anyone can offer anything more than "I know someone who know
someone....". The original design of these motors was definitel
deficient and their fix came too late. It contributed substantially t
the ruination of OMC, more through the loss of reputation than th
quality of their products
Lynn Coffelt
bradleyj
Ho Boy! Lots of feedback again, here. I would try to keep in mind that
the lower frequencies are what will be useful in attracting USCG and
commercial vessels in the 100 mile range. Not too familiar with East Coast
HF traffic, but here 4125KHZ would be useful. On these lower frequencies the
17' whip isn't likely to perform any thing like the 23' whip you mentioned
earlier. Some auto tuners will be jumping in and out of tune as you transmit
with either the 17' or 23' as your craft rolls and pitches in a stormy sea.
I'd opt for the 23'er for 4125 any day.
Look closely at the lower swivel mount you intend to use..... I'm not
sure there are any stainless swivel mounts on the market that will allow
free movement in more than one plane. If you use non-metallic line (I guess
we're talking synthetic braided rope here) for guy wire/line support,
there's GOING to be movement judging from the size and shape of the vessel
in the picture you posted. REAL MOVEMENT! It will surely make short work of
that lower mount.
As a practical matter, when the seas get snotty, and your engines are
swamped out, you don't need a downed antenna thrashing around the gunnels
after the bottom end of the antenna has suffered a failed mount, or one of
the guys has parted.......... now is when the radio is supposed to earn it's
keep. More than one of my old customers can tell you all about why the SSB
using a well anchored emergency battery is worth all the fish you've got in
the box.
I still think the best compromise, by far, is the old hat system of a
two-piece mount on a vertical surface, metallic or not. You may lose a
percent or two of efficiency, but at least you'll have an antenna. If you
absolutely must use guys, (perish the thought), use good stainless steel
aircraft type cable, available at most larger general hardware stores, and
insulators at the lower end of the cable. "Egg" or "aircraft" in-line
insulators work ok, and they prevent the guy wire/cable from being part of
the ground system. From the looks of your picture, the guys are not going to
be long enough to be any substantial part of a wavelength on the lower HF
bands, so a single insulator at the end nearest the pilothouse overhang
would do it. The "egg" or "aircraft" type insulator, if you are not
familiar, is designed so if the insulator cracks, breaks or disappears, the
two cable or wire ends find themselves looped together and the guy only
gains about an inch or so in length.
Another thought, The Shakespeares (smashed by heavy seas) that I've
seen, have the radiating wires, four, usually, imbedded in the fiberglass
shell fairly near the surface. If you drop a plate over the fiberglass to
attach guys, try to provide something to keep the plate from working around
and wearing through to the radiators not far under the gelcoat.
That's my story, and I'm sticking to it......
Old Chief Lynn
7
2K
Larry
9
1K
Gary Schafer
116
8K
Bruce in Alaska
32
4K
Bruce in Alaska
