1) after the inverters where it says "SW1" (And SW2 Sw3... ex.) What is that? or is that meant to be a label for each switch? looks like a connection. not sure how to read that.
{/QUOTE]
Those are measurement points for the simulator. You can ignore those.
2) The Resistors before the displays. It just says "R200" this is meant to be resistor arrays? and if so are they 200 Ohms?
Yes...they are 200 ohm resistor arrays. I tried to choose a resistor value that would limit LED segment current to the middle of the range. Max is 30mA, so the resistors limit current to about 15mA. You can change these if you like. Just do the math like Gryd3 show'd you in post #28.
3) the connection #'s or notations between said arrays and the 7 segment displays. what are these?
Again, those are measurement point for the simulator. You can ignore those. There are really just straight wires between the resistors and LED display.
4) the other 2 regarding the segment displays and the resistors at the bottom. I'm not finding anything with the #. and just wanted to double check that these were the same as the ones i have and we talked about before.
The LED's I've shown in the schematic were just for the simulation. You would use the ones you chose in an earlier post. The only thing is that your LED spec says 1.8v Vf and 30mA max. I calculated the resistors based on using 1.8v@15mA.
And the resistor (and all above really) can you point me in the right direction as to what I should be looking for?
there are so many different resistors with different ratings and kinds I don't want to get the wrong ones.
thanks!
All resistors can be 1/4 watt, or greater, 5% tolerance .I tried to use standard values that are easy to get. If you change the LED current limiting resistor values, be sure to account for any increase in current and check power discipation. I'm assuming you'll be using through hole parts. The resistor circled at the bottom is 1 megaohm.
One thing I should mention is that a 0.1uf, 50v cap should be connected from +V to ground at each chip's positive supply pin to keep noise down. Could be a small ceramic disc cap.
