Computer-controlled electric regenerative braking is much more flexible
and responsive for other than straight dry road conditions. I worked in
R&D for both antilock braking in the 1970's and the Segway so I've seen
the limits of both up close (and can't reveal details of either of them).
This discusses the subtleties of substituting controlled regeneration for
part or all of the friction brake.
http://green.autoblog.com/2011/04/19/countdown-to-earth-day-regenerative-braking-102/
The pounding you feel when you trigger your ABS shows what happens when
solenoid valves modulate brake fluid pressure.
Notice that regenerative braking can become a serious hazard on icy roads,
and to a lesser extent wet corners. There are times when only pushing in
the clutch to let the wheels roll freely allows you to regain control.
BTDT a lot, in parking lots and frozen lakes. The computer can't detect an
icy patch ahead, and sometimes even the driver can't.
"As soon as you hit an area like that when using coasting regen, your
wheels are going to lock because you have a lot of force, and then you
render our ABS system useless because the ABS can't go anything when the
wheels are locked."
You are too stubbornly narrow-minded to see the flaws in the magic tech
you have become so pathologically attached to.
