Malcom \Mal\ Reynolds
Lots of things _can_ be made. Lots of things that _can_ be made are
not practical.
Rick said:"The Stirling engine is noted for its high efficiency compared to steam
engines...
, ...quiet operation, and the ease with which it can use almost any heat
source.
Morris Dovey said:I want to buy a Stirling engine in the 1-2 hp range suitable for using in
a solar heat (~750F) context. Do you have, or can you find, a link to a
product with a price comparable to internal combustion engines in that
power range?
Rick said:I'm sorry Morris but other than replying to the post that apparently
Stirling engines do appear to have at least some practical use in the
conversion of solar energy to electricity, I have no involvement
whatsoever, however this engine manufacturer was mentioned in the Wiki
article.
<http://www.infiniacorp.com/application.html>
Rick said:I'm guessing that a version made now, 60 years on, would be considerably more
efficient?
vaughn said:How so?
Interesting, but it doesn't appear to be in the same price class as
Briggs & Stratton (et al). I've done a lot of searching, but it doesn't
appear that anyone is offering consumer-affordable products.
Still looking - and hoping (but not holding my breath).
Yep. The Stirling does have some hope of practical use. I will make
a prediction that if it ever does, it will be in a very limited
application. For sure beats out the wackos pushing "the Amazing Air
Car", the "Psuedoturbine" and the like
Rick said:I was thinking along the lines off comparing the efficiency of a 60 year
old cars generator to a modern alternator.
Johny B Good said:Which losses also apply to the dynamo.
However, a further improvement in efficiency can be obtained by using a
permanent magnet based rotor and using a switching regulator to
efficiently convert the varying (with speed) output voltage to the desired
DC output voltage.
This principle is used in the "inverter" based generator sets such as the
Honda EU3000i with its "eco throttle" feature where the DC output is used
to power the 50/60Hz 230/120 volt inverter module.
Whilst the inverter based genset designs might seem to have introduced
additional losses (most notably that of the inverter module), the
efficiency difference is insignificant compared to the two benefits
conferred which are:
1) Decoupling of generator speed from the AC output frequency which allows
engine speed to be used as the main form of output power regulation when
the eco throttle feature is enabled.
2) Decoupling of reactive loads (in particular, leading currents due to
excess capacitance) which can adversely effect voltage regulation in the
classic (cheaper) AC generator based genset designs. In fact it this
'feature' that makes them so unsuitable for powering Personal Computers
(especially when protected by an in line UPS).
The output voltage regulation of a switching sinewave inverter remains
totally unaffected (within defined limits) by such reactive loads. For
example, a cheap 2.8KVA genset I once owned, would, on its 230v regulated
output setting, overvolt to 280v when connected to a 4.7 microFarad PF
correction capacitor borrowed from a 20W fluorescent light fitting. An
inverter based genset would suffer no such deficiency.
Daniel who wants to know said:I still like the Toyota hybrid method, no alternator, just a PM rotor
motor/generator (MG1) and a regulated DC-DC converter for 12v battery
charging. It is kind of an inverter generator integrated into a car.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I beg to disagree.
It could be argued that laminated armatures are far stronger than one
piece, cast versions. Each lamination has a hardened 'skin' on it that
forms during the manufacturing process.
They are certainly more vibration resistant than cast pieces. The reason
they are cast is one of economics. It's cheaper than assembling laminations.
As for the co-axially wound field, it would make no difference. The
reason alternators can spin so high is the fact that it's the *field*
spinning instead of the main windings. The rotor wire is a lot smaller
than that of generator, resulting in a great reduction of centrifugal
force.
engines, quiet operation, and the ease with which it can use almost any
heat source.
This compatibility with alternative and renewable energy sources has
become increasingly significant as the price of conventional fuels rises,
and also in light of concerns such as peak oil and climate change.
This engine is currently exciting interest as the core component of micro
combined heat and power (CHP) units, in which it is more efficient and
safer than a comparable steam engine."
True, but the Stirling has a low power density, which means it gets very
big to produce significant amounts of power. This is especially true is a
low-grade heat source is used because the heat transfer surfaces must
become very large. The Stirling engine is almost 200 years old, yet I have
never seen one. There are multiple reason why they have neve become
common. .
of practical use.
I will make a prediction
Morris Dovey said:...It appears that it /may/ be possible to incorporate a 100kW
Stirling-driven generator capacity comfortably into a Cooper Mini.
Morris Dovey
It powers French and Swedish submarines.
Please don't.
I'll make another prediction.
Morris Dovey said:On 12/20/11 9:32 PM, harry k wrote:
Agreed.
It also sits at the focal point of a large mirror and generates electricity.It powers French and Swedish submarines.
