Sensor interface, OP AMP, -500mV +500 mV to 0-5 V amplifier
Good comments from GPG. I assumed that since the sensor output -0.5 to 0.5V it was already amplified by an op amp, but apparently not. So a buffer amplifier is required before the summing (or differencing) amp.
One more thing, though:
Even a rail-to-rail amp will not allow the input to go all the way to zero with a single supply. So you should either use dual supplies, or map the range to something not including 0, such as 1-5V if you prefer to use a single supply.
Bob
Yes Bob, that's why I used -1 Volts, but it could be -5V. So a combination of my circuit and yours should fit the bill.
Adam
Also the output will go to within 15mV of the rails into a high resistance load.
The only thing missing is whether a few nA input current is ok or should pA be required. OP?
