Hi
I have tried to post a scematic in different formats all less than 3mb but get errors.
Output needs to be 0.65V (tolerance of 1%).
The width has to be 100ms.
I have generated the pulse using a dc dc converter Ltc 3549, which gives exactly the output i require. The sensor heater is at 150mA.
So we pulse the heater first, then apply 3V and read the output V sense.
From 3V and Vsense we can obtain RS resistance of sensor.
I need to test 5 to 10 sensors and need to pulse each sensor in turn. Hence i am trying to switch the 0.65V DC pulse. Sensor 1 is pulsed, each additional sensor is pulsed 6 seconds after each other. After 10 sensors we return back to sensor 1.
The load the pulse is driving is 510R.
I have a pfet. Source at 0.65V, output will be the drain. I have a pull up 47K between gate and source to keep the fet off.
The gate of the fet is fed from collector of npn via a 10K. The npn has a 10k at the base connected to the PIC I/O. A logic 1 turns on the npn, pulling the gate low. I thought the pulse will now be at the drain and load?
If i pulse the emitter follower with 1.3V pulse, then i will get a 0.65V at the emitter.
So can i get the dc dc converter o/p into an emitter follower?
Thanks in advance.
I will try the upload again.
