David Lesher
Sure it does. You have a big fat switcher that can be
precisely controlled and you don't have to stack several
telco switchers. Stacking switchers is always a white-knuckle
scenario.
The switcher in the VFD's I know are switching rectified line
voltage to create 3 phase; there are thus six sets of power
semis. The control function is to vary the frequency while
firing the semis in sequence. The output is 3phase AC, but
hardly sine waves.
I can't see what that has in common with a high power multi-tens
of KHz switcher, with a transformer suitable at the frequency &
power level.
The control circuitry is easy, what's difficult are the ferrite
transformer, the big semiconductors and the layout (for good EMC). The
latter are all done. I don't think you will find the perfect solution
with your desired control gear on a silver platter for this job.
While I've not repaired any VFD's, I've read a bunch of spec sheets
while seeking one. None I saw alluded to a HF transformer.
UPS and VFDs _are_ switching supplies. For the UPS kind you just have to
make sure that it is a true power conditioner type and can work sans
battery.
The UPS's I have scraped have real, 60 Hz, transformer iron.
