Hi everybody,
I have a little problem in assigning a footprint
to a 8 pins relay using "OrCAD Layout".
I have a power relay with 8 pins: 1 for coil1, 1 for coil2, 2 each for
NO, NC and COMON. Lagically speaking this component has 5 connetions
(coil1, coil2, NO, COMMON, NC) but 8 fisical connections.
So I have designed a schematic component with 5 pins and a footprint
with 8 pins.
So here comes the problem:how can I assign 2 padstacks to a same pin?
I am a bit baffled..."Layout" doesn't allow to rename two different
padstacks with the same name or link two pads with a same pin.
Hints?
Reagards,
Alex
with 8 pins.
Hints?
Reagards,
Alex
